Author Topic: felt a bit bumpy  (Read 3303 times)
Offline navmk4gti
Re: felt a bit bumpy
« Reply #10 on: 13 October 2009, 23:53 »
mine felt like that today after i pumped them up  :undecided:
Offline Rhyso
« Reply #11 on: 14 October 2009, 08:27 »
aren't you supposed to replace all 4 tyres at the same time on 4 wheel drive vehicles??
could be a difference between the two brands you have on there  :undecided:
get the tracking checked and get the wheels re-balanced and go from there
Offline the_stink
  • A3 140 TDI
« Reply #12 on: 14 October 2009, 08:44 »
The Tracking was checked when they were replaced, the rear driverside was replaced a couple of weeks ago when the valve went on it and the rear passenger side has got tons of tread on,
I know your supose to change all 4 at the same time :p
im going to go to the tyre place after work to get them to check the balancing
Offline Rhyso
« Reply #13 on: 14 October 2009, 08:47 »
don't forget that temperatures are dropping now so that will have an effect on the tyres performance
I noticed a big drop off in performance last year when i was running the old GSD3's on my Monty2's - anything below 5C and you had to be that little bit extra careful :afro:
Offline the_stink
  • A3 140 TDI
« Reply #14 on: 14 October 2009, 09:00 »
Well hopefully it is just a silly weight that has fallen off, will check the tyre pressures as well, did a round trip to reading the day they were fitted to see Guy
Offline Rhyso
« Reply #15 on: 14 October 2009, 09:04 »
I had that with mine after i had two new fronts - a weight didn't fall off but ended up in a different place - it was fine until you sat at motorway speeds  :sad:
Got them re-balanced last week and all is well  :smiley:
Offline the_stink
  • A3 140 TDI
« Reply #16 on: 14 October 2009, 09:14 »
yeah i mean it was feeling iffy at 50 so thats never good :P
Offline Rhyso
« Reply #17 on: 14 October 2009, 09:15 »
must have helped your MPG though as i bet you weren't going as fast  :tongue: :laugh: :laugh:
Offline the_stink
  • A3 140 TDI
« Reply #18 on: 14 October 2009, 18:41 »
hahah the only thing that can help my MPG is a clear road and green lights!!!
went to the tyre place after work and managed to sort the problem they re balanced the wheels one was out by bloody 25!! but did a test on the dual carriage way after to make sure  :evil: can drive at 50 with no probs now  :rolleyes:
Offline richw911
« Reply #19 on: 14 October 2009, 18:54 »
Good news bud :afro:
