Author Topic: LED side lights  (Read 18801 times)
Offline TagnuT
  • Edition 30
Bye Bye Edition 30
Offline Merlinman
  • Tornado Red 170ps GT Sport
Re: LED side lights
« Reply #41 on: 24 November 2009, 19:56 »
I've had them on for 3 months now - no problems yet  :wink:
Offline Bigs
Re: LED side lights
« Reply #42 on: 04 February 2011, 23:58 »
Helloo!
Apologies if this sidelight led has been mentioned before but it's a cracker and wanted to share it! I tried one recently from hids4u but it didn't spread the light widthways enough in the light enclosure as it only had two light outputs. This one has five and it spreads the crisp light a treat. Remember though, if it doesn't illuminate, just spin it around 180 degrees. On my ed30 i lifted the charcoal canister out of the way (driver's side) to have easy access. A small pair of thin nosed pliers worked a treat and i was all done in five minutes. The led light works superbly with xenons especially. Cheers.
http://cgi.ebay.co.uk/501-W5W-No-Canbus-Error-LED-Sidelight-Interior-Bulbs-/280587962572?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item41545888cc#ht_5256wt_1222
turbo lag = automotive foreplay
Offline Obbzi
Re: LED side lights
« Reply #43 on: 05 February 2011, 13:55 »
Helloo!
I just fitted some of those in my puddle lights they look ace!
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline 2007GTI
Re: LED side lights
« Reply #44 on: 08 February 2011, 21:25 »
I brought some of these and they are the first ones that work!
they look ace in sidelights, problems is, even tough I have osram silverstars, they make them look yellow!
might buy some more for number plate lights/puddle lights.
Offline biggaz41
Re: LED side lights
« Reply #45 on: 13 February 2011, 12:54 »
Obbzi - how did you go about swapping the puddle lights mate? Fancy having a bash at mine, bet they look great!
Also interested in trying to change the footwell lights if anyone has any tips or know if its possible/easy etc?
Offline Obbzi
Re: LED side lights
« Reply #46 on: 14 February 2011, 04:01 »
Easy mate! Just one torx screw to remove, then the plastic lense slides out, old lamp out new LED in 2 mins!
Fancy doing the interiors next, never thought about the footwells, will do those as well!
Offline biggaz41
Re: LED side lights
« Reply #47 on: 14 February 2011, 14:04 »
Cheers mate, will have a bash at them
Offline moffspeed
Re: LED side lights
« Reply #48 on: 20 February 2011, 22:28 »
Helloo!
Quite agree - did mine and the difference was amazing - quite difficult to capture in a photo but perhaps this will give you an idea of the "whiteness"...
same issues with the polarity - the final trick seems to be to turn the ignition on and off a few times to "kick-start" these bulbs.
I also did the puddle lights - the  difference isn't so dramatic - but be aware that it's a simple procedure - just bend the mirror all the way forward to expose the single torx screw, undo the screw and remove the small housing with a flat-blade screwdriver, replace the bulb and you're done. Some websites/forums  suggest that you need to dismantle the whole mirror housing but this is not the case !
« Last Edit: 20 February 2011, 22:42 by moffspeed »
Offline R32 Mad
Re: LED side lights
« Reply #49 on: 25 February 2011, 18:20 »
