The garage
CV Boot repair
Topic: CV Boot repair (Read 9058 times)
Khare
Serious forum addict
The bear that khares
CV Boot repair
12 October 2009, 18:19 »
OK. End of next month I have the MOT. My o/s inner boot and my n/s outer boot are split. Is there anyway, I can "patch" them up to get through MOT? I don't have the:
a) money
b) time
c) space
d) tools
to do it in.
Is there anyway, or anything that I can buy/use on the CV boot to patch it up? (I'm thinking some sort of glue based product to stitch up the split).
Matty-MK3
Automatic boats FTW.
Re: CV Boot repair
12 October 2009, 20:28 »
They cost about six quid and would take half an hour to do. Need sockets, hex socket/allen key and hammer.
Take the wheel off, take the calliper off one side with hex socket/allen key (may just have 12/13mm nut TBH) then take the carrier off. Then the disc and undo the hub nut. Take off the ball joint and you should have enough space to get the CV out, knock it off with the hammer, replace boot & job done.
Sounds harder then it is.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge"
, auto windows all round and a AC. Oh and
I've
got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Khare
Re: CV Boot repair
12 October 2009, 20:34 »
I know but I just don't have the tool to do it, so I'd have to invest in tooling, which costs money. I'll see how it goes.
Matty-MK3
Re: CV Boot repair
12 October 2009, 21:05 »
Tool?
What tools? Sockets and allen keys?
I've
Khare
Re: CV Boot repair
12 October 2009, 21:06 »
Quote from: Matty-MK3 on 12 October 2009, 21:05
Tool?
Don't you need an oddly long allen key???
Paul86S2
Re: CV Boot repair
12 October 2009, 22:29 »
You can buy cv boots that wrap around and then glue together. Some you need to cut the old boot off and some wrap around the old boot left in place. Don't know what ones are available for the Golf.
A couple of problems with these:
Everything will need to be clean for the glue to adhere properly.
More importantly with a split boot dirt will have got into the cv joint and this will increase wear in the joint and cost you more money in the long run.
I personaly wouldn't go for a repair of the boot. Do the job properly and you will only need to do it once.
Paul
Khare
Re: CV Boot repair
Reply #6 on:
12 October 2009, 22:35 »
I know Paul, CV boot replacements are on the list, it's just that I need something quick, cheap and easy just to get it through the MOT next month. I will get round to replacing the old, worn boots at some point, and re-greasing the joints.
Matty-MK3
Re: CV Boot repair
Reply #7 on:
12 October 2009, 23:14 »
Get a glue on one then, but I must worn, they are complete crap but will get you through an MOT, just bung LOADS of grease in the split first then clean with petrol.
If they're on the list anyway, just glue on ones will do.
I've
Khare
Re: CV Boot repair
Reply #8 on:
12 October 2009, 23:21 »
Cheers dude. Now, where can I get the glue on ones???
Wayne
Sir Postalot
Re: CV Boot repair
Reply #9 on:
12 October 2009, 23:38 »
I would replace them now, you stand a chance of knackering the joints if you leave them.
The garage
CV Boot repair
