Author Topic: think i need a new starter motor? wheres best place to buy from?  (Read 4137 times)
Offline julie
its had a brand new heavy duty battery on it but still turns over slow then today wouldnt start
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
it may be brand new, but that doesnt mean leaving an interior light on / a wiring fault / alternator dead / slipping alternator belt wont cause it to be flat.
What voltage are you getting accross the battery?
what voltage are you getting at the starter?
cold weather exaggerates battery problems.
Offline dadrathers
Hi Julie
Yes it is the bush for the starter motor - I was being lazy/unclear in my description - sorry.
Still with battery and Chris White on this one.
Dadrathers
Offline kittie
Doesn't sound like a starter issue but couldn't miss an opportunity to condemn Euro some more - don't buy a new starter from them, mine broke after 2 weeks  :cry:
Offline julie
voltage is as it should be on the battery! as soon as i bought the new battery and put it on it has never started straight away always slow to turn over. no lights etc have been left on by mistake?
Offline Chris-White
double check the earth straps onto the battery, may not have attached properly.
My raddo was a b!tch for this, the earth strap was crap, so when you tried to start it, the current drain killed everything.
Offline julie
starter motor changed! all fixed,starts first time now.  :smiley:
Offline Ben Lessani
Did you replace the bell housing bush ... if not - don't expect the new starter to last that long :(
Offline julie
yeah bush got changed,old one was pretty much non existant!
Offline DarnPB
  • Formerly Darnpistonbroke
