Author Topic: ferrodo front brake pads  (Read 818 times)
Offline RnP
  • Audi S4 gone, looking for b5 rs4
« on: 12 October 2009, 11:45 »
Halfords have started selling these and im wanting to get a set for the 1.8t, after speaking to the guy in the parts dept, he claims there are 2 different variants one of which is 146mm wide and the other being 80e marked with wear indicator, anyone know which is the one i need??
price is reasonable too £61 all in
Offline northeast_gti-t
  • "1.8T AGU"
Re: ferrodo front brake pads
« Reply #1 on: 12 October 2009, 12:26 »
if you have a brake pad wear indicator warning light on the mfa on your instrument cluster then you want the pads with the wear ind wiring plug  :wink:
2000 Mkiv GTi 1.8T AGU
  • "1.8T AGU"
« Reply #2 on: 12 October 2009, 13:03 »
just to add if you look at the front brake pads passenger side front i think there should be two wires coming from the caliper area one will be your abs sensor and the other will be the brake pad wear sensor (if fitted) this should be clipped to the strut and is a long plug iirc
