Author Topic: Mk3 1.4 oil leak  (Read 5233 times)
Offline Sonic2
Re: Mk3 1.4 oil leak
« Reply #10 on: 12 October 2009, 15:34 »
Ah I see, never had to take the pressure switch off before, but i've done the reversing light switch before.
cant check it now as im in a call centre until 5  :sad: but I shall check it out then.
Must admit, it would be the last place i'd check with the way its coming out the bottom (and has been) but definately sounds possible.
Even my dad and his next door neighbour didnt see anything when looking at it and thought the seal with the way the old one was looking with sealant on it.
Offline Ashley
« Reply #11 on: 12 October 2009, 19:06 »
There's a rubbery gromet which goes over the top of the sensor making it difficult to tell to look there..
It's not a definite ofcourse, but its a good bet.
Offline MowatGTI
« Reply #12 on: 12 October 2009, 20:08 »
When you say the leak is worst when running, it may well be it only leaks when running.
Keeping in mind that it takes time to run down the engine.  It will still drip down even after 30 minutes after stopping the engine.
If thats the case - it won't be around the sump area.
Offline Sonic2
Re: Mk3 1.4 oil leak... and now the header tank is hissing
« Reply #13 on: 13 October 2009, 08:27 »
Thanks guys, its definately the pressure switch, pulled off the rubber cover and its leaking from there  :smug:
i'll take a trip to the vw garage in my lunch break, its only 5 minutes away from where I work. hopefully I can get it off with an adjustable wrench (Its very close to the dipstick mount), if not i'll ask my dads mate for a big enough socket to get on there.
Also noticed the coolant header tank is hissing slightly so i will get another one on there from the vw breakers when I can - 2 faults located in less than 24 hours!... :smug:
Offline Ashley
« Reply #14 on: 13 October 2009, 10:57 »
congratulations, you're the first person i've ever actually helped  :nerd:
Offline Sonic2
« Reply #15 on: 13 October 2009, 11:15 »
Ty  :cool:
Never would have thought of looking there, it is tucked away a little bit. It was hooning out of there!
The header tank explains my slow loss of coolant too, so its been a good time getting the car back to shape.
Offline Sonic2
« Reply #16 on: 13 October 2009, 13:54 »
VW didnt have it, (£11) got a non oem one from a parts store next door to where I work, less than a fiver  :smug:
However, couldnt fit it in my lunchbreak as the biggest socket ive got is 17mm, and the adjustable wrench wouldnt get on it, even after taking off the engine hoist locator off  :sad:
So, i'm off to my dads after work for a bigger spanner, or socket!
This poxy thing WILL come off!  :smug: lol
Offline axewielder
  • 95 dragon 8v
« Reply #17 on: 13 October 2009, 13:56 »
not hard, just the right f off big spanner  :laugh:
Offline Sonic2
« Reply #18 on: 13 October 2009, 14:15 »
yeah not difficult with the right sized socket at all, would have been off with my adjustable wrench if it was the blue one next to it!
Just no access there on the white one with a wrench...
Offline Sonic2
« Reply #19 on: 14 October 2009, 08:54 »
All sorted now, just gotta steam clean the engine down now, and stay away from the carb and air intake.
For anyone doing the same job, you'll need a 24mm socket, or spanner, but the latter makes it much harder.
thanks again  :smiley:
« Last Edit: 14 October 2009, 09:58 by Sonic2 »
