Author Topic: how exactly does a 20v engine work???  (Read 7592 times)
Mixologist
Re: how exactly does a 20v engine work???
« Reply #10 on: 24 September 2004, 12:30 »
yup your assumpton of the v5 is correct, not sure how they balance it though but they are nice and smooth!
Gaz 8)
sorry for quality of pic, i was (as you can imagine, very pi55ed off at the time!!!)
So the drinking vast quantitys of beer didnt help the picture taking ;)
Whats the point in a 20v, why not just make a 16v with the same size area in the valve caps ???
Offline the boy mike
« Reply #11 on: 24 September 2004, 12:47 »
Mix; the whole point of having 5 valves is so that you can fit more valve area in.. you physically couldn't get more area with 4 valves - hence the relationship between 2 and 4 valve per cylinder engines - with 4 you can physically fit in more valve area, and suck in more mixture. More valves also make the engine more tractable at low engine speeds as the two (or three) smaller ports help to keep intake velocity high - giving the air more inertia and filling the cylinders better at low RPM - giving more torque.
Gambit; having seen a 20v head, I think you'd have a problem fitting a spark plug and a fuel injector in there..
In a turbo application you should be able to get away with worse breathing characteristics as the turbo is ramming more air in at higher pressure anyway..
Offline Dizzie
  • Make friends with your fast
« Reply #12 on: 24 September 2004, 13:15 »
the spark plug goes down the middle of the valves like teh 16v's. the injector is on the inlet manifold pointing into the cylinder.
Mk4 Golf 150PD
Veedubgt18v
« Reply #13 on: 24 September 2004, 18:30 »
eh? ???
Well, two inlet, and two exhaust for each cylinder. Thats four, four times five, is 20.
i thought the 20v was a four pot engine?
« Reply #14 on: 24 September 2004, 19:26 »
Dizzie - you still talking about the direct injection / FSi lump, or the 20vT?
Veedubgti8v - The 20vT is based on the same block as the Gti lumps - 1.8 four pot. Each cylinder has 3 inlet and 2 exhaust valves (4x(3+2)=20) - unlike the old Audi 2.2 five pot, which had two inlet and exhaust valves per cylinder; 5x(2+2)=20.
You see ;)
kniterider
« Reply #15 on: 24 September 2004, 21:39 »
dont think its dizzie thats got confuesed here, as the injector does sit in the inlet manifold pointing into the inlet port, wether it be an old 16v or the new style 20v engines, the only difference is how many valves they squeeze in and how many lobes on the cams other than that (and maybe a little vvt ) there basically the same engines..........
4 cylinderx4 valves per cylinder =16v
4 cylinderx5 valves per cylinder=20v
5 cylinderx4 valves per cylinder=20v
easy to get confused peeps......
lol
Gaz 8)
Offline piggy
  • What you lookin' at sonny?
« Reply #16 on: 24 September 2004, 21:43 »
Yamaha were the first to put a 4 cylinder 20v engine out in the 80s.
They claimed that the optimum no of valves were 7! But could only justify 5 due to cost.  ::)
kniterider
« Reply #17 on: 24 September 2004, 21:55 »
cant beat motorbike engines!!! the bhp they get out of them is unreal!!! id love my 1800cc 16v to whale like a 750 20v yam at 12000 rpm (if it would rev that high and give twice the power out put as my mates race prepped yzf750 r m
Gaz
Offline piggy
« Reply #18 on: 24 September 2004, 21:59 »
Mind you it'd only last for a season before needing a full rebuild :P
It'd be like a blade engined chateram. Fast as F@ck.
