Author Topic: Will I loose my DAB radio ?  (Read 6568 times)
Offline mortygt140
Re: Will I loose my DAB radio ?
« Reply #10 on: 10 October 2009, 15:09 »
Just looking on ETKA and that doesn't show a difference in units and theres an external DAB unit that VW do,  but I was looking on a 2010 Golf so older units could be different??
Darren
Offline mortygt140
« Reply #11 on: 10 October 2009, 15:12 »
Forgot to say the version c RNS510 2660 f/w has done away with DAB you carnt even select it in the options so I think VW have stopped doing it any way.
Darren
Offline p3eps
« Reply #12 on: 10 October 2009, 15:15 »
Darren
Probably because it spends half its time cutting out as the signal is poop!
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline mac7
« Reply #13 on: 10 October 2009, 16:10 »
Darren
Useful info there Darren - confirms what I'd read on vwnavi.com. So the DAB tuner used on the RCD510 is a separate module then?
The PIN diagram on my-gti is different to my one.
That diagram I linked to was for an RCD, not the RNS - maybe that's why they're different.
To be honest I hadn't realised there was more than one version of the RNS510 sat nav unit - or is it just firmware updates?
Golf R
Offline p3eps
« Reply #14 on: 10 October 2009, 16:14 »
There are 3 versions so far - A, B and C.  Not sure if the hardware is different, or if its just software.  I know that my A-version is now on 2660 software - and has all the functionality of a C-version unit.  If you have an A-version unit with a hardware revision less than HW04 - then it can't take 32gb memory cards even with the latest FW - so there must be slight differences?
Offline VWKev
  • Please Support Non-Human Rights
« Reply #15 on: 10 October 2009, 16:15 »
Not the greatest photo I know - but it was taken with my phone!
Here is my RNS510 A-version (which is currently living under my computer desk!).
The PIN diagram on my-gti is different to my one.  It still has all the connectors - apart from that No.1 - DAB aerial input... although they're in slightly different places.
Judging by this, it must mean that the DAB tuner is built into the RNS / RCD - and if this is the case, you won't be able to do a simple swap unless you buy an RNS that has DAB built in.  :sad:  I'd imagine this would only be available in version C units?
I'm not convinced by the DAB anyway, as the car I test drove with it didn't get a good signal hardly anywhere!  Perhaps you should test out your one Kev before diving in and buying an RNS.  If you don't get a great signal - then swap it for a standard RNS.
Thanks P3eps, I'll give it a good test for sure.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline mac7
« Reply #16 on: 10 October 2009, 16:25 »
Who remembers the good old days when you just chucked any old stereo in your car and it worked.  :grin:
I think I'll give DAB a miss and worry about it if they ever actually switch off FM.
Golf R
Offline VWKev
« Reply #17 on: 10 October 2009, 16:31 »
I've got a portable DAB the same size as a personal radio, im off for a quick 10 min drive around to test.
Offline VWKev
« Reply #18 on: 10 October 2009, 19:20 »
Only lost reception twice, I went around Cambuslang, East Kilbride and around Rutherglen, Parkhead in Glasgow and it was fine, really crystal clear.
I really want to keep my DAB now, unless I can get it with the RNS510 I wont change from the RCD510.
