Author Topic: Found a problem  (Read 4464 times)
Offline T_J_G
Re: Found a problem
« Reply #10 on: 09 October 2009, 18:16 »
Can you give him a nudge to see if the lower breather pipes are ready? I broke mine replacing that top breather pipe so mine is taped up at the moment.
I still seem to be loosing power somewhere though. Might have to take a visit to R-Tech.
Is yours mapped yet? Can take you out in mine at some point!
Offline Stronz
  • Sold!
Re: Found a problem
« Reply #11 on: 09 October 2009, 18:43 »
Sounds like a plan. I keep meaning to come to brands too. Perhaps we can combine the two. First Wednesday of every month isn't it?
Offline northeast_gti-t
  • "1.8T AGU"
Re: Found a problem
« Reply #12 on: 09 October 2009, 19:17 »
good spot that tim  :laugh: least hopefully you'll get it sorted soon replaced mine not long ago in a worst state than yours  :grin: how much does eveything move in relation to the std tip openings with the forge one fitted  :huh: as i have my tip to fit  :lipsrsealed:
2000 Mkiv GTi 1.8T AGU
Offline T_J_G
Re: Found a problem
« Reply #13 on: 09 October 2009, 19:59 »
Last wednesday of every month! Next one not for a while :(
I'll get a picture for you tomorow matt, but not a lot
of movement.
Offline topher
  • Administrator
  • fully functioning
Re: Found a problem
« Reply #14 on: 09 October 2009, 20:34 »
  • "1.8T AGU"
Re: Found a problem
« Reply #15 on: 09 October 2009, 20:48 »
of movement.
cheers tim :afro: tho not looking forward to fitting it from what i'v seen!! just want it on tho how you finding yours tim?
Offline T_J_G
Re: Found a problem
« Reply #16 on: 09 October 2009, 21:05 »
I'm not sure mate, as I had exhast and the new map as well. I'm sure it makes a difference, have you seen the standard tip?
  • "1.8T AGU"
Re: Found a problem
« Reply #17 on: 09 October 2009, 21:32 »
from what i have read its a worthy upgrade yes had a look at your pics thats more or less what made my mind up and searched last night and found a video (as an example audi tt tip) std and it showed how it tried to suck itself in under hard boost  :shocked: went in by about 1" was defo convinced then that upgrade needed lol
Offline Grand Master Patch
Re: Found a problem
« Reply #18 on: 09 October 2009, 21:44 »
I've found that the forge tip is easier to squeeze than the std tip,i very much doubt they are any stronger tbh.
  • "1.8T AGU"
Re: Found a problem
« Reply #19 on: 09 October 2009, 21:51 »
its not stronger as such patch although the silicone is a better material  it was the fact that the std tip pipe tried to draw into itself when real hot and hard boost
