Author Topic: Just a FEW problems  (Read 2883 times)
Offline L33
Re: Just a FEW problems
« Reply #10 on: 13 October 2009, 20:31 »
why would i have to take it to VW, sure vag-com is there to replace going to vw haha.
Can you erase all error codes such as abs warning light with vag-com, sorry im "a bit" n00bish but its my first car, altho i am a quck learner so already sorted a few niggles etc out :)
thanks
Offline DrewGTI
« Reply #11 on: 13 October 2009, 20:57 »
but you said you dont have vag com as yet. . .
so just saying a trip to VW can sort out whats the problem sooner.  :smiley:
oh,as for your ABS light. . .prob a sensor gone done and needs changing.  :smiley:
one trip to VW could answer all your questions and then no guess work.  :smiley:
« Last Edit: 13 October 2009, 21:00 by DrewGTI »
« Reply #12 on: 13 October 2009, 21:23 »
+1
Offline L33
« Reply #13 on: 13 October 2009, 21:41 »
yea good point, off to VW dealership 2moz me thinks, or local VW specialist, i will have a laptop and vagcom soon though i hope.
thanks
p.s. "VR6 Joe" love ur car (Y)
Offline L33
« Reply #14 on: 14 October 2009, 12:52 »
taken ma car into VW today and apparently the split servo pipe should turn on the engine warning light not the ABS light and guess what...i have and ABS lght on but no engine service light lol.
its all booked in for tomorrow so hopefully they'll let me know tomorrow whats up with it.
once they have told me i may need help as ill be replacing components.
Thanks
Offline DrewGTI
« Reply #15 on: 14 October 2009, 18:08 »
you should get a read out of whats wrong with it etc. . .
then fix it yourself or get someone cheaper the VW to sort it.  :smiley:
or get VW to sort it.  :cool:
Offline L33
« Reply #16 on: 14 October 2009, 20:18 »
yea thats what i am goin to do. they would charge so much etc. just the read out will be mint and the support of you guys :)
Offline L33
« Reply #17 on: 15 October 2009, 10:14 »
just got back from vw, they only tested the brake system and the offside rear sensor is gone, should be an easy enough job :) and they said the high idle would be due to the split servo-manifold pipe, this true?
thanks
Offline L33
« Reply #18 on: 18 October 2009, 08:59 »
ive replace the pipe that leads from the servo to the inlet mainfold and now ma car runs great, no high idle speeds (The agg doent have a ICV) and really smooth idle rpm, it seems like the split pipe is a common problem, pretty much every golf i looked at in the scrap yeard had this problem.
Just leaves my ABS sensor to replace now, is it an easy job?
thanks
Offline bored_Welsh_lad
« Reply #19 on: 18 October 2009, 09:58 »
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
