Author Topic: rns510 trick  (Read 12787 times)
Offline R32UK
Re: rns510 trick
« Reply #10 on: 07 October 2009, 09:47 »
undue car and attention
That's what I thought, but they would have to prove it which is difficult. Unless like I said above, you were driving like a t1t.
Offline FroGTI
  • Wheel nut
Re: rns510 trick
« Reply #11 on: 07 October 2009, 10:09 »
Hmm, starting to lust after an RNS510 now... starts entering www.ebay.de...
Offline R32UK
Re: rns510 trick
« Reply #12 on: 07 October 2009, 10:21 »
honestly pal.. its probably the best thing i have bought for the car!! paid £700 over a year ago and they still go for around that price now :smiley:
well worth it!
Offline FroGTI
  • Wheel nut
Re: rns510 trick
« Reply #13 on: 07 October 2009, 11:16 »
Can you give me a quick list of all the 'extras' I'd need to get it going? Shark fin, software updates, etc. Did you fit it yourself?
TIA :smiley:
Offline Jam
Re: rns510 trick
« Reply #14 on: 07 October 2009, 22:05 »
How can you tell what firmware version you have?
Offline p3eps
Re: rns510 trick
« Reply #15 on: 07 October 2009, 22:17 »
On some units you can hold down the setup button for about 10 seconds and it gives you a hidden menu that tells you about version info etc.  If you want to check if you have the latest version, the easiest thing to do is try putting in an SD card that is MORE than 2gb.  The latest FW is the only one that will accept anything greater than 2gb.
Other than that - the sticker on the back of the unit tells you its original version.
[quote author FroGTI]
The required bits are the GPS Antena and the VW Code Card.  Optional extras are the V5 Map Disk, and the latest Firmware (probably required for the climate control to work), and a shot of a VagCom to get it coded to your MFD / steering controls.
Judging by this... fitting should take you about 10 mins - even if you don't know the first thing about car audio!
http://uk-mkivs.net/forums/t/297235.aspx
[/quote]
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline VWKev
  • Please Support Non-Human Rights
Re: rns510 trick
« Reply #16 on: 07 October 2009, 22:52 »
Excellent guide  :smiley:
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline mortygt140
Re: rns510 trick
« Reply #17 on: 08 October 2009, 06:32 »
Version info
Version A:
the most obvious is the volume level when altered comes up in the middle of the screen and the back ground dims,  Also go into the Tones  settings and select balance and fade if you have 2 rows front to back left to right then this is version A
Version B:
The above volume indication is down the bottom of the screen and the screen doesn't dim any more you will also get a different balance screen which shows you a top view of a Golf GTI/R32 interior and you have a scroll feature
Version C:
As above posted stick a SD card in that is more than 2gb also in all of the screens goto EXTRAS at the bottom of the screen and in there will be an option to turn the screen off also in MAP settings there is an option for visual speed limitations this will show you the speed limit of the road your currently on.
Offline VWKev
Re: rns510 trick
« Reply #18 on: 08 October 2009, 11:25 »
Just to clarify, all these versions are just firmware updates, no hardware changes ?
Offline R32UK
Re: rns510 trick
« Reply #19 on: 08 October 2009, 13:14 »
yep
