Author Topic: my clutch is slipping is there owt to check?  (Read 1747 times)
Offline shogun
  • its a golf day
Re: my clutch is slipping is there owt to check?
« Reply #10 on: 10 October 2009, 08:44 »
ive found the clip you mean and it was already clipped off , when i put it back on there was hardly any pedal at all i could push the pedal right down before i could feel it , so do you think it could want a new cable??
Offline Deano2711
  • 1992 VR6
« Reply #11 on: 10 October 2009, 09:12 »
When the clip is replaced the cable is longer to allow it to be fitted easily. You now have to remove the clip again and pump the clutch pedal a few times. Then test the car to see if clutch is still slipping. If it is still slipping you are looking at a new clutch and then a new cable is advised.     Good Luck     Deano
« Reply #12 on: 10 October 2009, 10:59 »
Yes sounds like it, when you fit the new one don't remove the clip untill after you have it connected up.
