Author Topic: DIY: changing interior reading lights to LED  (Read 14126 times)
Offline p3asa
Re: DIY: changing interior reading lights to LED
« Reply #31 on: 13 November 2009, 22:55 »
Let me know if you manage to change the footwell ones as I couldn't get in to them  :sad:
Offline FroGTI
  • Wheel nut
« Reply #32 on: 14 November 2009, 16:19 »
You can open them with a little care: pry the metal casing open with a flat-bladed screwdriver and the whole unit can be disassembled. The hard one is the glove box, as it has a resistor in it. Rathre than mess about, I simply ordered another footwell unit (cost about £3), fitted the LED bulb and then popped it into the glovebox aperture :wink:
Offline p3asa
« Reply #33 on: 14 November 2009, 16:25 »
Cheers.
Did you put different LED's in the footwell as the normal LED's would point to the side rather than down!!
Also the front dome, I followed the other thread but I'm unsure what bit to lever of as the other thread is for a MK V and different.
And welcome back  :laugh:
Offline FroGTI
  • Wheel nut
« Reply #35 on: 14 November 2009, 17:06 »
Cheers.
Thanks :smiley:
If I remember correctly, there's some kind of reflector in the housing to ensure that the light is focused downwards into the footwell. So yes, I used the same LED bulbs as in all the other locations.
As for the front dome, I followed the other thread and it worked a treat. I seem to remember using the second suggestion for accessing the bulbs.
Offline gossa
« Reply #36 on: 17 November 2009, 16:52 »
Cheers froggy, i've done them all except the footwells, what did you pop out exactly?
Offline p3asa
« Reply #37 on: 17 November 2009, 18:51 »
Cheers Mr Frog  :cool:
Gossa did you manage the front lights ok? I'm not sure exactly what bit is hinged and don't won't to force it.
The footwells looked a nightmare to remove. I took the wee box into the house and tried to ply it open but it wasn't for coming!!
Offline gossa
« Reply #38 on: 17 November 2009, 23:05 »
The fronts were easy, I have a small leatherman and used the knife to just prise bits out.  The centre bit in front of the plastic surround of the actual front lights pops out easily and then you can prise out the cover for the fronts.
So how did you get the footwell box out? It was dark tonight when I did all this!
Offline p3asa
« Reply #39 on: 17 November 2009, 23:17 »
You can lever it from the side no problem and the whole thing comes out.
Then just unplug it. It looks like this http://forums.vwvortex.com/zerothread?id=4337725
Despite trying, I couldn't remove the metal box even although I had wedged it open at both sides!!
