Author Topic: Mk3 golf Query!!  (Read 1825 times)
Offline laurielaeks
Mk3 golf Query!!
« on: 03 October 2009, 18:27 »
Howdy, Im in the middle on a 16v conversion and was wondering if anyone could help me out,
Does the hydrolic clutch and cable clutch use the same pedal box?
Because it was originally a cable clutch and the new gearbox is hydrolic clutch, just wondering if i bought the hydrolic stuff, wether it would be plain sailing or if id have to do alot of work changing the pedal box?
Thanks for any help in advance
Re: Mk3 golf Query!!
« Reply #1 on: 04 October 2009, 00:25 »
Different I believe
Offline Paul86S2
« Reply #2 on: 04 October 2009, 01:08 »
yes differant, but instead of changing the peddle box etc you can change a few bracket and the lever on the gearbox to make it a cable change box. I believe they are from the seat ibiza. Someone more knowledeable will be able to give you the exact details and part numbers.
Paul
Offline laurielaeks
« Reply #3 on: 04 October 2009, 09:04 »
ok think i might just have to go that route then, would it have been hard work fitting a new pedal box?
