Author Topic: Window seal.  (Read 1024 times)
Offline christomk3gti
Window seal.
« on: 01 October 2009, 23:27 »
hey guyz.
the outer seal on the rear driver side window at the bottom is lifting up abit, I can push it back down but it eventually lifts back up.
whats causing this? is it easy to remove and refit?
Its lifting up at the point where the movable rear window meets the rear unmovable window. If you know what i mean lol.
anyway i want it sorting, coz i looks cack.
 :smiley:
Black 8v GTI............. Whats a Waffle Valve?
Re: Window seal.
« Reply #1 on: 01 October 2009, 23:32 »
It will be the clips on the trim, I had the same issue and never really found a cure not sure how much a new trim wold be.
Re: Window seal.
« Reply #2 on: 01 October 2009, 23:34 »
Its on the outside of the car. Not sure if you thinking the same thing wayne???
Its the rubber seal...
Re: Window seal.
« Reply #3 on: 01 October 2009, 23:38 »
I am thinking about the one at the lower edge of the glass, as and when the window was raised it would lift up.
Re: Window seal.
« Reply #4 on: 01 October 2009, 23:47 »
yeah, the seal on the window (outside the car) (that runs all the way round the rear door window) thats whats lifting up slightly at the bit where the 2 windows are split....
if that makes sense lol.
