Author Topic: ABS warning light comes on help pls  (Read 7118 times)
Offline nadlad
  • Building Surveyor MRICS
Re: ABS warning light comes on help pls
« Reply #10 on: 05 October 2009, 17:28 »
just bought a new abs sensor from vw for 50.00 gonna put that on tomorroew
<<<Big Build Thread>>>
Offline nadlad
« Reply #11 on: 06 October 2009, 18:47 »
after fixing the new abs sensor from vw the problem still persists!
i had vag on it today adn it threw up this fault G45 front right sensor, i have noticed that the grinding noise only happens when no warnign lights are on i.e yellow triangle and asb light, if the asb light and the yellow triangle are on which is usually after the forst time i brake then i dotn get the slow speed grinding noise... pls shed light
Offline Steve_PD
« Reply #12 on: 06 October 2009, 18:53 »
take the wheel off and have a look around for signs of the metal wearing, any sharp edges or shiny metal.
it wont be the abs sensor as you already had a new one fitted
Offline nadlad
« Reply #13 on: 06 October 2009, 18:59 »
mate pls help me!!!!!
ave had the wheel off ave checked everywhere there is no ign of metal scrapign or shear marks anywhere do u think the actual sensor wire coudl be damaged when he unplugged it doubt it though thsi has all happened since the f**kign cv joint
Offline Steve_PD
« Reply #14 on: 06 October 2009, 19:06 »
cant see it being the actual sensor, I would have thought the abs ring on the hub.
can you jack the car up and rotate the wheel to see if you can hear anything :undecided:
Offline nadlad
« Reply #15 on: 06 October 2009, 19:54 »
yeah they ring looks perfect no signs of wearing
Offline jimbooboo
  • YUM YUM
« Reply #16 on: 06 October 2009, 20:40 »
If it only grinds when the lights are on maybe something is activating not sure what, like your brakes or something causing the noise, im no expert but just reading thru this i thought i'd share my thought.
Offline nadlad
« Reply #17 on: 06 October 2009, 21:06 »
yeah am still thinking about this
Offline nadlad
« Reply #18 on: 06 October 2009, 21:09 »
the think is as steve pd says the ring and the end of the abs have tiny surface areas and this grind noise is more a deeper heavier impact what am trying to say is i dont think if them two bits rubbed the niose wud be as loud as what i have
Offline nadlad
« Reply #19 on: 07 October 2009, 18:17 »
ave decided to get the new wiring loom from vw for 30 quid this feeds to the abs and brake pad gonna see how this goes fingers crossed for saturday i can only think it has to be a wiring fault.
