Author Topic: Indicators and Rear lights gone mad!!!!!  (Read 2067 times)
Offline ace
« on: 30 September 2009, 22:03 »
right as i was driving this evening i noticed that when i put my indicators on, they would stop blinking when i pressed the brake. when i got home i checked the rest of my lights and basically when i indicate the rear lights start blinking as well, whats worse is that the inidactor on the other side will also blink very slightly.
confused with this, where would i start to check first  :huh:
Offline Adam
Re: Indicators and Rear lights gone mad!!!!!
« Reply #1 on: 30 September 2009, 22:06 »
That would be a bad ground
Down Hill From Here.
Offline Deano2711
  • 1992 VR6
« Reply #2 on: 30 September 2009, 22:06 »
Sounds like a dodgy earth connection on the rear lights.  Check them out.     Cheers     Deano
Offline ace
« Reply #3 on: 30 September 2009, 22:10 »
what would cause a bad earth connection???
also sorry for my stupidity where is the earth connection on the rear lights???
Offline Deano2711
  • 1992 VR6
« Reply #4 on: 30 September 2009, 22:17 »
Dodgy earths could be caused by either the connections getting dirty or the earth leads breaking or just simply coming loose. You should find the earth leads near the light fittings in the boot. It will bolt onto the body right by the light.     Cheers     Deano
Offline ace
« Reply #5 on: 30 September 2009, 22:19 »
cheers mate will have a look tomorrow
Offline christomk3gti
« Reply #6 on: 30 September 2009, 23:07 »
definately bad earth.
mate had a same issue, he just re earthed it. no issues with his now.
Christo
Black 8v GTI............. Whats a Waffle Valve?
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 01 October 2009, 00:01 »
while your there check the rear light seals,circuit board for the bulbs and the wiring connector as the gaskets are useless with age (and even worse with some aftermarket lights!)
Offline ace
« Reply #8 on: 01 October 2009, 11:44 »
right just checked the earth connection, clean the contact points but still no luck.
any other ideas??
Offline harlemex
« Reply #9 on: 01 October 2009, 12:24 »
check the circuit board on the bulb holder as boney says.
