Author Topic: Brink towbar query  (Read 698 times)
Offline spaceboy
Brink towbar query
« on: 30 September 2009, 21:55 »
Evening all,I have recently purchased a genuine VW "Brink" towbar offa ebay........have fitted him,but havent got the bumper back on yet......do I need to cut/trim this around the ball area??.....Im really hoping not,as that is why I waited to find a genuine one......Thanks
Si  :smiley:
Offline spaceboy
Re: Brink towbar query
« Reply #1 on: 06 October 2009, 21:46 »
I thought I would post my findings on the finished job,as I have found various threads useful to me on here.....I read on some threads that the bottom black plastic part of the rear bumper was a fixed part ,this is not the case on my J plater....it;s a fiddly job but doeable with patience.....I was lucky enough to have the towbar that was genuine so plugged into the N/S rear light unit....so easy.....it also has the removal towing swan neck,I bolted the towbar up,removed the towing neck,bolted the back bumper back up and got the lines right.then I used a white touch up paint stick and from underneath marked either side of the tow bracket....then removed the bumper again and hole sawed through the black plastic lower trim......if I remove the towbar to sell it,all I need to replace is the trim not the expense of paint etc.....hope this may help someone.
