Author Topic: front brake caliper rubbing issues  (Read 2427 times)
Offline JackJack
Re: front brake caliper rubbing issues
« Reply #10 on: 01 October 2009, 11:12 »
While I'm here.. If my old alloys had an offset of 32 and these 35s are catching would a 3mm suffice?
thanks alot :smiley: hopefully I can have this sorted by tomorrow morning
Yes and the bolts will be fine.
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 01 October 2009, 13:07 »
what wheels did you have with the 32 offset?? std wheels are usually et43
Offline JackJack
« Reply #12 on: 01 October 2009, 13:47 »
Again they're rs4 reps. I couldn't find another pair with an offset of 32 so had to go for 35s
Offline ace
« Reply #13 on: 01 October 2009, 14:12 »
yeah as already stated, spacers will work fine, i had this problem previously spacers fitted job done  :smiley:
VW BUSH
« Reply #14 on: 01 October 2009, 14:54 »
VW Audi parts in Angmering West Sussex :smiley:
Offline JackJack
« Reply #15 on: 02 October 2009, 10:11 »
FFS  :cry: Bought the stupid lil 3mm spacers from halfords and they dont fit properly. Think i've discovered first hand why they're called Halfrauds. I'm either going to need 6mm and above spacers or just change the brakes back to standard (They need doing anyway)
Offline JackJack
« Reply #16 on: 02 October 2009, 10:28 »
Where can I buy wheel spacers that isin't from Halfords in West Sussex/Surrey?  :angry:
Edit: And where can I buy 20 60mm wheel bolts?
« Last Edit: 02 October 2009, 10:55 by JackJack »
« Reply #17 on: 02 October 2009, 11:33 »
Why do you need to change the brakes, I ran et35 with no issues.
Offline JackJack
« Reply #18 on: 02 October 2009, 11:44 »
I need new discs and pads I meant sorry, theyre pretty worn down
Offline JackJack
« Reply #19 on: 02 October 2009, 18:47 »
Bump :drool:
