Author Topic: Alloy wheel offset question  (Read 4736 times)
Offline JackJack
Re: Alloy wheel offset question
« Reply #10 on: 28 September 2009, 14:59 »
Yeah just examine the wheel carefully mate and write down all the numbers you see on a piece of paper and then put them on here, I'm sure one of us can work it all out for you.
Best place for a spare wheel - probably ebay or a scrappy I'm afraid :(
Just had a quick look at the wheel itself and wasnt sure what to look for. Where exactly would any numbers or wording be? Or would it tell me on the tyre? I'll try and upload a picture in the next hour or so?
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 28 September 2009, 15:06 »
et is usually stamped on the inside of the spoke (along with size and commonly the manufacturer's details)
oh and be careful if your buying replica's as there not always identical (I looked at buying another rs8 wheel but on ebay and i saw a few that were slightly but to me noticeably different)
Offline JackJack
« Reply #12 on: 28 September 2009, 15:44 »
Ah on the wheel it says something rim "7.5j" would that be the width of the alloy?
« Reply #13 on: 28 September 2009, 15:47 »
Yes that is the width.
Offline JackJack
« Reply #14 on: 28 September 2009, 15:52 »
Nice one just need to find the offset now haha
Offline lewis1641
  • stuck in the 90's
« Reply #15 on: 28 September 2009, 16:45 »
try looking under the centre cap or around the edge of the rim on the inside. it MIGHT say "IS" instead of "ET" - i have seen a few german wheels with is - it means the same thing.
if you do buy a single replacement and it is a diffenent offset you can correct it with spacers.
if your other wheels are et35 and the replacement is et 38 the you would need a 3mm spacer for the new wheel. if yours are 38 and the replacement is 35 then you would need 3 3mm spacers for your existing wheels
hope that helps
Offline JackJack
« Reply #16 on: 28 September 2009, 17:19 »
 :cry: :cry: :cry:
Right I just took it up to the tyre and exhaust garage down the road to have a look as there was no writing or numbers on the front of the wheel at all.
The offset in the end was et32.
But great news... I now have TWO cracked alloys.
Argh so annoyed, I've now got to fork out for a new set of alloys  :sad:
« Reply #17 on: 28 September 2009, 19:14 »
:cry: :cry: :cry:
Check on here you will / should get a set s/h cheaper.
Offline JackJack
« Reply #18 on: 28 September 2009, 19:49 »
:cry: :cry: :cry:
Thanks, I'll keep an eye on the classifieds.
While I'm at it what offset wheels will fit a golf?
« Reply #19 on: 28 September 2009, 20:22 »
:cry: :cry: :cry:
Et32 to Et37 is ok and works best.
