Author Topic: If you have the 510, Dynaudio and Ipod please answer this question....  (Read 4705 times)
Offline Ady189
Hi all,
I have the 510 plus Dynaudio option fitted
I use my ipod with it a lot.
I have a problem that when I select the 'Songs' option and the list of songs come up that when I select a song its not the one that gets played. Weird this is that for example if I select a song at the top of the list (starting with an 'A') it plays songs by ACDC, when I select a song starting with 'B' it plays badly drawn boy.
However if I select songs by going through 'Artist' then pick the album and then pick the song it plays the right thing??
Do any of you get the same issue, want to check before I go back to VW and report it
thanks
paul
I don't even know how to get it to play the ipod?
I've got the 510 (I think) with the dvd nav etc.. it has an aux port and a media in port.. what do i do to get it to play songs from my ipod/phone?
Offline AlanH
Get your dealer to supply you with an iPod lead. This connects to the port in the armrest, with the other end connecting to the iPod. Select the "Media" button on your 510 and you should see the Ipod contents. Only works if you have the dedicated armrest with the media/aux sockets!
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline Mighty_G
  • Tornado Red MK6 3 Door, 18 inch rims, AAC, RCD510
I've just tried it, and on my 310 system, if I go into that poxy "songs" menu, it does in fact play any track I select.
I don't know why yours doesn't do that, but it seems like a fault in the software to me.  If you've got your music all backed up, you could try resetting the iPod back to factory settings then reloading the music.  (if that's a big hassle, don't, because it's only a suggestion and it might have nothing to do with that.)
Is it playing the first track alphabetically under that particular letter of the alphabet, no matter which song you select?  it sounds as if that's what you're describing.
Rolfe.
thanks Rolfe, looks like it may be my Ipod, going to try someone else's, if that works then will reset mine, if it doesn't then I'll report the fault to VW
cheers
paul
