Author Topic: Help with 8v Gti Starting  (Read 3497 times)
Offline andd306
Re: Help with 8v Gti Starting
« Reply #10 on: 27 September 2009, 22:05 »
well i took the hose off which goes to the injector rail and it pumps out when cranking! there seems to be a smell of fuel when trying to start it!
Also im 90% sure i can hear the pump priming.
The more i think about it the more i think it must be a fuel or ecu problem, because surely if the engine is timed up correctly and i have a full set of sparking plugs the only thing missing is the fuel?
Is there a injector test i can do or possibly something that can go wrong when disconecting the wires?
Is there a way of resetting the ecu?
Andy
Offline leegt5
« Reply #11 on: 27 September 2009, 22:21 »
The fuel pump priming is quite easy to hear I just checked mine on the way home. When you turn the ignition before starting there will be a hum from the back of the car for a second and half and then stop. To reset the ECU, disconnect the battery for 30+ mins then reconnect.
Offline andd306
« Reply #12 on: 28 September 2009, 18:59 »
i can hear a priming noise coming from the engine area but not from the rear of the car! But when i remove the petrol pipe going into the injector rail and turn the engine over it poors out of the pipe so it look like there is a supply!  :shocked:
Offline leegt5
« Reply #13 on: 28 September 2009, 19:02 »
And everything is plugged back in ? Sounds like the injectors are not injecting the fuel if your getting a spark !!
« Reply #14 on: 28 September 2009, 19:11 »
Earth lead left off and spiked / blown the ecu by any chance.
Offline andd306
« Reply #15 on: 28 September 2009, 20:08 »
Earth lead?
How can the ecu blow?
Andy
« Reply #16 on: 28 September 2009, 20:17 »
Earth lead?
Andy
Poor earth and then trying to start it can spike the ecu and blow it, seen it happen on mk2's a lot.
Offline andd306
« Reply #17 on: 28 September 2009, 20:25 »
any way of testing it?
Offline leegt5
« Reply #18 on: 28 September 2009, 20:29 »
Suppose if you could connect and read your ECU with vagcom then the ECU must be working, may also give you a clue as to what the problem is !!
Know anyone with vagcom ??
Offline andd306
« Reply #19 on: 28 September 2009, 20:31 »
nope afraid not! everything else still works!
