Author Topic: JonL's 8v budget track toy - now going to be a race car! ;-)  (Read 89952 times)
Offline Horney
Re: New Member and another 8v budget track toy project
« Reply #40 on: 29 September 2009, 10:51 »
Fair enough. I'm pretty sure Mark has a proper list of what he did and what he used somewhere. No doubt he'll appear on this thread at somepoint and fill you in.
Nick
Offline Horney
« Reply #41 on: 29 September 2009, 11:01 »
Offline JonLeeper
« Reply #42 on: 29 September 2009, 11:07 »
Nick
I hope not, all I did was ask the question! ;)
VeeDubGTI16v
« Reply #43 on: 29 September 2009, 13:52 »
errrrrrr  :sick:  :grin:
there is a few ways to do it, but the way i did it used the following bits-
passat wishbones
passat steering arms
passat driveshafts
10mm spacer behind the stub axle ( can use a stub axle from a golf with drum brakes with the stub milled off)
ford cosworth bolts to replace the stub axle bolts (higher tensile rating and longer, ill try and find the part numbers in a bit)
6mm normal wheel spacers on the back
this widens the track 16mm per corner  :afro:
the only hard job is removing the steering arms from the rack with everything on the car, and the stub axle bolts can be a bit of a b!tch to get out without snapping
Offline JonLeeper
« Reply #44 on: 29 September 2009, 14:28 »
passat wishbones
passat driveshafts
Know what you mean! ;)
I take it that the Passat hubs can be used with carriers and brakes as well?
VeeDubGTI16v
« Reply #45 on: 29 September 2009, 14:34 »
i think so. just make sure that the hub and caliper carrier are seperate items, then you can use 256mm or 280mm discs on the hubs. the 8v hubs for 239mm brakes are all one piece so bigger discs cannot be fitted
im only down the road from you if you want to have a look at what ive done
Offline JonLeeper
« Reply #46 on: 29 September 2009, 14:41 »
I would love to have a look but transport is an issue, until the MOT is passed ;), so will have to wait a week or so.  I will then be looking to see who has what seats and stuff as well to see what I need to get.  Many thanks for the offer and I will take you up on it.  I will also have to try and see Horney's as he has been very helpful so far.
Offline JonLeeper
« Reply #47 on: 01 October 2009, 14:42 »
Right another quick update (read slow day at work! ;)) and to keep you all abreast of my progress, I know you are all hanging on my every move! :kiss:
I went out last night, after returning from an interminable all day meeting in London, and collected a crimping tool and some connections from Halfrauds and then popped round to Jamie’s and collected the windscreen washer bottle and the horn switch.  All good to go now, less the CV boot of course, and this lunchtime I decided that the weather was too good not to fit at least a little bit and took an extra ½ hour to tinker.  Result is that the rear number plate now has two lights, the rear fog is permanently fixed and the loom zip tied back together, the horn switch is fitted and I have fitted and removed the washer bottle!  It fitted back nicely and I tested that it worked (jets need aligning but that’s all), all fine, then when I went round to tighten the fixing nut I noticed that water was pissing out from the bottom of the bottle.  I blocked off the rear washer line and it was still leaking so I assumed that the bottle would need fixing.  Off it came and I took it inside to wash and inspect, thought about using the dishwasher (but my Better Half would not have understood!) and dismissed the idea very rapidly.  A quick wash-up, in the sink, later and I refilled it to test.  With the pump hole covered it held water fine so all I can assume is that the seal didn’t and I need to be very careful when I refit to prevent the water just pissing out when I fill it up.
So that is all of the MOT jobs, including the only advisory (horn switch) I am going to worry about (fitting the rear seats and belts back in is not going to happen) except the CV boot.   Tonight’s job is to jack up the front and have a look which boot it is and, hopefully, get the old one off ready too go and buy another.  If al goes really smoothly I might just have a chance of retesting on Fri and being able to actually drive the car at the weekend!  Wish me luck,
Jon
Offline JonLeeper
« Reply #48 on: 01 October 2009, 14:44 »
Oh just as I remember I have bought a set of 15” rims from e-bay and bid on a new fog light switch.  I now don’t need the switch as the one I have has decided to work, but for £2.00 and les than that in postage if I win it will not break the bank!  I will need to go and collect the rims and then buy some tyres but they will be my new track wheels, I hope!
Offline Horney
« Reply #49 on: 01 October 2009, 14:53 »
Nice work Jon, have you put any thought into what tyres you're going to go for?
Nick
