Author Topic: Suspension porn!  (Read 5659 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Suspension porn!
« Reply #10 on: 20 September 2009, 15:22 »
seriously nice  :wink: will look spot on once you get them fitted :afro:
and why are they not fitted yet  :laugh:
2000 Mkiv GTi 1.8T AGU
Offline Hurdy
« Reply #11 on: 20 September 2009, 23:55 »
very nice..  :cool: :cool:
I take it the numbers mean they are adjustable??
Yup, adjustable 10 setting damping :smiley:
Is the damping adjustable for both compression and rebound damping?  :undecided:
Yes :cool:
Seat Leon Cupra Black 290 DSG
shrocco
« Reply #12 on: 20 September 2009, 23:56 »
Yes :cool:
not so cool when you'll put them on one setting that works, never change the settings again and the valves seize up.
Offline Hurdy
« Reply #13 on: 21 September 2009, 14:15 »
Yes :cool:
That is a possibility, but I'll have at least 3 or 4 combinations to use fairly regularly as I'll need at least a road setting, a track setting and a drag strip setting. All quite different. As long as you protect them from the start you shouldn't have issues with them seizing. The fact that I'll alter the settings 20-30 times a year should help avoid seizing. :smiley:
Offline Teutonic_Tamer
« Reply #14 on: 23 September 2009, 12:16 »
Yes :cool:
So each leg has TWO separate adjusters?  :undecided:
I feel like a homo
Offline Hurdy
« Reply #15 on: 24 September 2009, 01:21 »
Yes :cool:
No, they aren't INDEPENDANTLY adjustable for bump and rebound. The one adjuster does both, so adjusting for a harder bump dampening will give you a harder rebound dampening. :smiley:
« Reply #16 on: 24 September 2009, 22:22 »
Yes :cool:
Ahhhhhh, I see.  Thanks for clarifying. :afro:
Anyway, hurry up and get them fitted! :tongue:
I feel like a homo
Offline Hurdy
« Reply #17 on: 24 September 2009, 23:12 »
They are on Sean :cool:
Work very well too.
They feel great on the car. Currently running setting 1 on the front and 3 at the rear. Tried 10 at both ends earlier and now need a new lower spine   :shocked: Imagine riding a pushbike with no suspension or seat at 60mph and you get the picture. Handled bloody brilliantly on that setting though :smiley:
Not got a pic of the car as it stands yet, but here are a few pics of them in various states of fittage.
Quick pic of the lowerage.....yes the car does need a clean  :embarassed:
« Reply #18 on: 24 September 2009, 23:47 »
Cool! :cool: :cool:
Just remember the next time you crank them up to ten, make sure your chiropractor is with you too!  :grin: :grin:
Are you going to upgrade the ARB drop links, because they will now very much be a 'weak link'!
I feel like a homo
Offline Hurdy
« Reply #19 on: 25 September 2009, 21:22 »
Cool! :cool: :cool:
I've had a look at the BSH ones (but not much further for other makes), which look very substantial, but I'm just seeing what the handling is like before I make my next step :smiley:
