Author Topic: Converting the 1.8 GL to a 2.0 GTi, what exactly do I need?  (Read 9908 times)
Offline Shady Pioneer
  • graphic designer.
Re: Converting the 1.8 GL to a 2.0 GTi, what exactly do I need?
« Reply #30 on: 18 September 2009, 17:31 »
Well cheers for that pal, so if I decide to do anything I just need to find an engine that
matches the same gearbox code? So I'd keep my ECU and then upgrade the brakes and exhaust system...interesting :p
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #31 on: 18 September 2009, 17:31 »
Actually, check your handbook if you have it, it will have the gearbox code in there, a 3 digit code. Then we can match it up. Are you going AGG code engine, easiest I think as it's most common IIRC.
Also, are we all confident the exhausts are different? I'm not too sure on that...
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
  • graphic designer.
« Reply #32 on: 18 September 2009, 17:39 »
I don't have the handbook im afraid, if I remember correctly, boneybradley told me my exhaust, at least he backbox, was the same size as an 8v one, where is he?
Offline Matty-MK3
« Reply #33 on: 18 September 2009, 17:41 »
Doing research it looks like the 16V manifold might fit the 1.8 but not the 8V, that sounds stupid to me.  :huh:
EDIT:
Looking at these:
GTi 8V mani
1.8 mani
They look the same, so I'd bet they'd fit you know.
Alternatively, you could find a good donor car, I've seen one on here for £150 an 8V that was rusted to hell. Then you would have all you need, you could even sell your wheels and get the 5x100 versions or just use G60 discs and whatever else LL was saying you will need.
« Last Edit: 18 September 2009, 17:47 by Matty-MK3 »
Offline Mikester
  • Civic Type R
« Reply #34 on: 18 September 2009, 18:33 »
If the shafts are the same I would use the 8v box. As for exhaust I'm not sure if the bore is the same?
Offline Matty-MK3
« Reply #35 on: 18 September 2009, 18:36 »
I suppose the bore could be different, but on my GL, a full exhaust from the downpipe was put on by Kwikfit by the previous owner and the receipt say's "2L 8v" or something, I can scan it if it will help in any way.
« Reply #36 on: 18 September 2009, 20:55 »
Reference the brakes, why not fit a set of grooved discs and same fast road pads, it is only 25 bhp more and your not going to track days it at the end of the day, rear drums will be ok up to a point if well set up or run a mk2 disc set up.
  • graphic designer.
« Reply #37 on: 18 September 2009, 20:58 »
That is along lines I was thinking Wayne, no real need for bigger brake discs as the power output is minimal.
« Reply #38 on: 18 September 2009, 21:00 »
It will be fine, the standard set up with good quality pads and grooved discs is all you really need.
« Last Edit: 07 December 2011, 13:47 by Wayne »
Offline Mikester
  • Civic Type R
« Reply #39 on: 18 September 2009, 21:28 »
I only have an 8v but wouldn't give back my 288mm grooved and green stuff pads for drums! Lol
