Author Topic: bypass TB heating?  (Read 10384 times)
adamrob69
Re: bypass TB heating?
« Reply #10 on: 18 September 2009, 10:31 »
if you change the temperature of the air after the air temp sensor, surely the mixture is going to be wrong and cause unpredictable running.
Offline Len
« Reply #11 on: 18 September 2009, 10:36 »
Anyway cooling it with water from the cars cooling system you cannot use a feed from the expansion tank as that is hot!
You would have to come off from the bottom hose out of the radiator.
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
  • The bear that khares
« Reply #12 on: 18 September 2009, 10:39 »
what are you implying?
Offline axewielder
  • 95 dragon 8v
« Reply #13 on: 18 September 2009, 10:58 »
Also, where can I get the caps to block off the TB ends, or what can I use to block them off?
Why do you need to plug anything?
and yes i agree that the temp sensor is as the airbox so it wont be perfect
« Last Edit: 18 September 2009, 11:01 by axewielder »
Offline Len
« Reply #14 on: 18 September 2009, 11:07 »
Well I thought this idea was about COOLING! Well you cant do that with HOT water!  :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #15 on: 18 September 2009, 11:08 »
Plus the TB is at the back of the engine and you will be fighting against the hottest part ie the exhaust manifold.
www.sas.org.uk
www.the-ace.org.uk
Offline axewielder
  • 95 dragon 8v
« Reply #16 on: 18 September 2009, 11:18 »
there is already coolant pipes running to the TB to warm it, i have removed them + by passed the coolant straight to the expansion tank from the front of the block, maybe there is a different setup on other engines.
BTW took about 3.5 mins with just a leatherman so not a difficult mod
Offline Len
« Reply #17 on: 18 September 2009, 11:35 »
Only air/vacuum hoses on my TB!
www.sas.org.uk
www.the-ace.org.uk
Offline axewielder
  • 95 dragon 8v
« Reply #18 on: 18 September 2009, 11:42 »
so thats why you didnt understand, i just thought it was your blue lights  :wink:
Offline Khare
« Reply #19 on: 18 September 2009, 11:51 »
axewielder, did you notice any difference?
