Author Topic: 160 Degree Oil Temp : /  (Read 2375 times)
Offline GTIMatt
Re: 160 Degree Oil Temp : /
« Reply #10 on: 12 September 2009, 20:04 »
Ok so I found it  :grin:
Disconnected it, then reconnected it looked clean did the spades, no rust. dash was showing ---. so I went for a drive because I'm sure I read somewhere it will only show temp once it gets going.
Ten minutes later, still showing ---. Water temp at about 1/4. Let it stand for a couple of minutes to heat up, even the fan came on but still ---.
I'm thinking the sensor is fudged?
Offline Diamond Hell
  • Opinions я Us
« Reply #11 on: 12 September 2009, 21:48 »
If the wiring looks good then it'll be the sensor.  Swap it out to find out for sure.
