Author Topic: Rear top mounts  (Read 1935 times)
Offline braderz
Rear top mounts
« on: 10 September 2009, 12:40 »
my car is currently having its rear suspension top mounts done, under warranty from place i got it from :) however they keep putting me off saying its not ready still, apparantly they have to drop the whole sub frame out? and its a really big job? is this true lol as i have no idea how major this is. hopefully will get it back soon!
Offline braderz
Re: Rear top mounts
« Reply #1 on: 11 September 2009, 09:29 »
well anyway....
car is alot smoother and stable to drive now, would recommend it
Re: Rear top mounts
« Reply #2 on: 11 September 2009, 14:28 »
Should not need to remove the subframe for top mounts, unless you mean bushes.
Offline bored_Welsh_lad
Re: Rear top mounts
« Reply #3 on: 12 September 2009, 07:55 »
i was thinking this too... its a ten min job to do..
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline braderz
Re: Rear top mounts
« Reply #4 on: 12 September 2009, 09:30 »
well they may have done both then, as it took 2 days  :rolleyes:
Re: Rear top mounts
« Reply #5 on: 12 September 2009, 11:11 »
The rear bushes in the beam are a right thingy aparantly...
http://forums.vwvortex.com/zerothread?id=3242686
see here...
Bumper Vents :D
Re: Rear top mounts
« Reply #6 on: 12 September 2009, 17:20 »
Top mounts take about 30mins to do, so it must have been the rear bushes.
