Author Topic: 8v vs 16v torque debate  (Read 5078 times)
Offline Gambit
« on: 14 September 2004, 16:48 »
maybe this will put an end to it
*borrowed of ClubGti forum* ;D
« Last Edit: 14 September 2004, 16:50 by Gambit »
Offline davidhawkins_78
  • Valver Bad Boy
Re: 8v vs 16v torque debate
« Reply #1 on: 14 September 2004, 16:53 »
Lol ... we still going on about this ??? :o ;D
I'd like to see what a chipped 8v running on Optimax would do compaired to the 16v ??
« Last Edit: 14 September 2004, 16:55 by davidhawkins_78 »
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 14 September 2004, 17:08 »
Surely you'd have to compare it to a chipped 16v running optimax  :P
Interesting graph, never really took much interest in the 8v\16v debate (lets face it 20 valves and a turbo dominate  ;D ) but i never thought the claims of higher low down torque figures on the 8v were true, you live and learn ! Upto almost 3k rpm too, impressive.
Offline Gambit
« Reply #3 on: 14 September 2004, 17:11 »
std against std ;)
im just putting the final nail in the coffin of those that say 8v's have more torque low down than 16v's
that graph shows they dont, they are more or less equal until 3k then 8v tails off & 16v takes off ;D
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #4 on: 14 September 2004, 17:15 »
Just to ask a question, is there any/much difference in the gearing between an 8v and a 16v or do they run the same box and ratios?
The greatest leveller of them all - the Carousel
Offline tobz.
« Reply #5 on: 14 September 2004, 17:16 »
I think I'd be right in saying that the 16v runs a closer ratio box with a lower ratio 5th than the 8v, correct me if I'm wrong guys.
You got any pics of your dad's split ?
Offline Gambit
« Reply #6 on: 14 September 2004, 17:20 »
yep 16v's are slightly more close ratio
8v's are more or less the same except for slightly longer 2nd & 5th gears
a 16v box with an 8v 5th gear is what you want
  • Valver Bad Boy
« Reply #7 on: 14 September 2004, 17:21 »
Yup - shame you had to go to such lenghts to prove the point !!
As for a chipped 16v - it's not possible to do so. ?;D
I'd love to see both car's again when they're 'loose' - I'm sure the differences would be the same, but the power figures seem to climb for both ?;D
A few 8v's made it well in to the 120bhp area in the AMD rolling road session, if the same goes for a stock 16v then 150bhp for a stock engine is fecking gr8 !
Offline Gambit
« Reply #8 on: 14 September 2004, 17:24 »
lol maybe i should make it a sticky all on its own with the title "16v are better than 8v fact"
 :P :P :P :P
  • Valver Bad Boy
« Reply #9 on: 14 September 2004, 17:26 »
Dam u snobby 16v owners  ;D
