Author Topic: Help with 1.3 cold running issues - sometimes  (Read 2009 times)
Offline mwep201081
Re: Help with 1.3 cold running issues - sometimes
« Reply #10 on: 09 September 2009, 23:17 »
mines now 25!!! but I've replaced most things!!!
« Reply #11 on: 10 September 2009, 09:59 »
yeah the white thingy is a accumulator/vapour seperator smooths out the flow of fuel and removes any bubbles. if you can get em cheap enough its worth a go.
ive seen peeps fix similar problems to this by putting the pump feed direct to the carb, problem there is you loose the fuel tank return, soi i expect it'll use a bit more fuel than normal?
Offline JMallows
« Reply #12 on: 10 September 2009, 17:29 »
Is the accumulator removable/cleanable without breaking? I could see if theres any crap in there or something?
A lot of my stuff is original, which i suppose is good, and bad
A clever person solves a problem. A wise person avoids it.
« Reply #13 on: 11 September 2009, 12:02 »
not sure really, worth a look anyway! worst case plumb the feed from the pumpy direct to carb, see em running like this all the time
Offline JMallows
« Reply #14 on: 11 September 2009, 18:56 »
Cool, thanks i will have a look and let you know
Offline weazgti
« Reply #15 on: 12 September 2009, 10:09 »
Heh.used to bypass that with my clipper 1.8 that had fuel tank full of rust.
Pulls fuel through much harder with it disconnected.Also i had a1.3 years ago that kangarood when you tried to pull away and my dad used to have to bend a spring on the choke to stop it doing it.
Sorry cant go in to more detail on that but carbs are witch craft to me.
