Author Topic: Trouble opening boot !  (Read 1260 times)
Offline Silky
« on: 14 September 2004, 14:33 »
Cant get the key to go in all the way on the boot lock, it does have central locking but its playing up at the minute, is there any way I can get the boot open.. ??
Phase 2 Peugeot 205 GTI
BMW E36 328i Sport
Offline tobz.
Re: Trouble opening boot !
« Reply #1 on: 14 September 2004, 14:39 »
You'll have to climb into the boot and remove the black rectangular piece of plastic from the inside of the tailgate. This will give you access to the lock and catch release mechanism, it should be easy enough to work out what to push, pull or press in order to open it.
Rear locks are quite prone to seizing up through lack of use on a mk2 fitted with central locking (due to the fact that the shape of the rear end sucks so much grit and crap up from the road surface).
You got any pics of your dad's split ?
Offline Silky
« Reply #2 on: 14 September 2004, 15:32 »
Cheers Tobz, will try that one out as soon as poss   ;D
BMW E36 328i Sport
