Author Topic: ACC and 19' alloys  (Read 3551 times)
Offline Fred_du_94
ACC and 19' alloys
« on: 07 September 2009, 20:07 »
Hi,
Has anybody fitted 19' alloys while having the ACC option ?
Any issues to report ?
Offline mac7
Re: ACC and 19' alloys
« Reply #1 on: 08 September 2009, 11:03 »
I guess the only issues would be if the weight of the wheel and tyre were significantly different - that would change the unsprung weight and might affect the ride a little. A significantly heavier wheel/tyre combo could make the ride in Comfort a little bouncier. I think... Where's T_T when you need him?  :smiley:
On the subject of ACC, does anyone know if any of the suspension manufacturers plan to make an ACC compatible kit?
Golf R
Offline FamilyDub
« Reply #2 on: 08 September 2009, 11:44 »
Posting in the MKV section  :nerd:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Teutonic_Tamer
« Reply #3 on: 08 September 2009, 15:28 »
Providing you get alloys from a quality manufacturer, then wheel weights should be fairly similar.
I feel like a homo
Offline Fred_du_94
« Reply #4 on: 09 September 2009, 09:16 »
Hi Guys,
Thanks for your answers.
Basically the combination ACC+ 19' alloys on the G6 GTI is possible.
I was asking this because on the VW Scirocco this combination is simply not possible. Not too sure why though...
Offline MDSS MK6
« Reply #5 on: 10 September 2009, 11:50 »
Seems pretty possible from this pic
Cancelled Order
Mk5 R32 instead.....and change too:)
« Reply #6 on: 10 September 2009, 11:54 »
Hi Guys,
Yup.  Just make sure you keep the rolling radiuses the same. :wink: :smiley:
I feel like a homo
