Author Topic: Major misfiring in 4th and 5th gear  (Read 1940 times)
Offline fused
Re: Major misfiring in 4th and 5th gear
« Reply #10 on: 06 September 2009, 23:17 »
I've been having probs with my'90 8v. I've tried just about every thing!! my symptoms are different but a few things to check/try is the arm and cap which are so cheap that you should just change them to be safe! the ignition control module, which sits on top of ecu. the hall sender/dizzy might be a problem but new ones are pricy over £100! so try and borrow a dizzy! have you changed your fuel filter recently? also check for vacuum leaks on all your hoses, as these can cause huge probs. does it happen at certain RPM or Speed?
Offline ianmaxtec
« Reply #11 on: 13 September 2009, 19:41 »
did you ever get to the bottem of this problem? was it the coil? curious, as I had a pal with the same problem, and it was the coil
