Author Topic: Tyre wear  (Read 14274 times)
Offline bored_Welsh_lad
Re: Tyre wear
« Reply #10 on: 08 September 2009, 07:29 »
I read a guide on a track prepped car, i think it was in PPC a while back, he had a gauge in car with tyre valves that fed back the pressures of each tyre.. some needed to run as much as 5psi extra on 1 wheel when cold compared to others to get a stable pressure all round when hot.. He said it was the best 200 quid he'd spent..
http://www.amazon.com/Hella-Pressure-Monitoring-Adjustable-Background/dp/B000QSDZQC
might cost a bit initially but cheaper than new tyres every trackday..
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
VeeDubGTI16v
Re: Tyre wear
« Reply #11 on: 08 September 2009, 10:03 »
my £5 pressure gauge ebay special will do  :grin:
i find the fronts go up 4-5 psi and backs 3-4 psi when hot
Offline Pike
Re: Tyre wear
« Reply #12 on: 08 September 2009, 12:11 »
What he said  :smiley:
Golf GTI Championship #4
2008 VW1 3rd
2009 VW1 3rd
Offline Paul86S2
Re: Tyre wear
« Reply #13 on: 08 September 2009, 15:35 »
Looks like you had a good day by all accounts.
I usually run my tyres in the 35 to 45 psi range on trackdays (when hot) but my car is a bit heavier than yours.
Did you get the alignment re-done when you had the shocks changed recently?
There are at least 2 types of compound on the R888's, you haven't got the soft sprint ones on by mistake have you?
Paul
Offline Horney
Re: Tyre wear
« Reply #14 on: 08 September 2009, 15:42 »
Hi Paul,
Yeah the day was awesome, back of the circuit hopping over the rumble strips at speed was soooo much fun. Felt like a touring car driver!
I have to confess to not having the alignment re done after changing the shocks but a bit of toe in or toe out would have had equal wear on the fronts I wuold have thought. The other side wore exactly as I would have expected. All 4 tyres are GG's as well.
Looks like higher pressures are indeed the way forward.
nick
Offline Organisys
  • Old and Slow...
Re: Tyre wear
« Reply #15 on: 08 September 2009, 15:56 »
Get the alignment done nick,as this could be too much toe in
Offline Horney
Re: Tyre wear
« Reply #16 on: 08 September 2009, 15:58 »
I'm going to mate, but between getting the shocks fitted and the car MOT'd I had no time to get the aligment done before the trackday. Will be getting new camber bolts and full front suspension alignment before the next trackday.
nick
Offline Diamond Hell
  • Opinions я Us
Re: Tyre wear
« Reply #17 on: 08 September 2009, 21:30 »
Ahem, well at least that solves the mystery of how Nick *possibly* used up quite so much of that tyre on one day.....
Offline Horney
Re: Tyre wear
« Reply #18 on: 08 September 2009, 22:49 »
Yeah it probably didn't help but the other 2 Golfs suffered pretty much the same as me.
nick
  • Opinions я Us
Re: Tyre wear
« Reply #19 on: 08 September 2009, 23:09 »
Who would have thought dodgy maintenance was so common among Golf2 track car owners?
 :grin:
