Author Topic: HELP!!!!  (Read 3735 times)
Offline mac456
Re: HELP!!!!
« Reply #10 on: 04 September 2009, 22:01 »
def sounds like the clutch is slipping, does it not regain power at all? before you change gear?
in my old car, it was like i had nos lol, it slipped then it felt like a big boost! lol wen the power caught back up  :grin:
Offline jeynesey
  • Non VW but still VAG
Re: HELP!!!!
« Reply #11 on: 04 September 2009, 23:06 »
Yeh it does catch up, but by then im at the rev limiter so having to ease off the gas and change gear  :sad:
Patch, cheers for your help mate, approx how much do you think for parts??
Nick
Offline Adam
Re: HELP!!!!
« Reply #12 on: 04 September 2009, 23:40 »
Time for an upgrade you say?
Here is a song -
http://www.youtube.com/watch?v=VSygqiOyD9M
:evil:
Down Hill From Here.
Offline richw911
Re: HELP!!!!
« Reply #13 on: 05 September 2009, 10:57 »
Nick
Have read through here bud:
http://www.golfgtiforum.co.uk/index.php?topic=87775.0
Where did you get caught speeding?  :cry: :cry: :cry: :cry:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: HELP!!!!
« Reply #14 on: 05 September 2009, 11:21 »
The price has changed slightly on my bargain clutch, gone up by about £6 so not too bad
Offline jeynesey
Re: HELP!!!!
« Reply #15 on: 05 September 2009, 22:48 »
Offline jeynesey
Re: HELP!!!!
« Reply #16 on: 05 September 2009, 22:51 »
Nick
Cheers Rich, so if I need it urgently this could be the best option??
http://www.vwspeed.co.uk/volkswagen/vw-parts/5_Spd_1_8T_Mk4_Golf_228mm_Clutch_Flywheel_Kit-1316-19.html
How difficult is it to fit? Ie how much labour would it take do you think?? Also any ideas from anyone how much it would be to replace for standard parts??
Cheers for all the advice! Nick
ps speeding in my home town, 36 in a 30, fecking mobile camera! :cry:
sh!t week so far!
Offline james2
  • No scammers please.
Re: HELP!!!!
« Reply #17 on: 06 September 2009, 00:18 »
check out youtube vw mk4 oem ecu 2 step full throttle shift.....
« Last Edit: 06 September 2009, 00:41 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline richw911
Re: HELP!!!!
« Reply #18 on: 06 September 2009, 10:49 »
Nick
ps speeding in my home own, 36 in a 30, fecking mobile camera! :cry:
sh!t week so far!
Standard set up will be much more expensive believe it or not   :wink:
It just bolts straight on same as fitting standard set up .
IIRC i got all the parts and fitting for 340 pounds  :evil:
Around 4hs labour i would think bud.
Dam sorry to hear about the camera - might be able to go to one of those speeding courses to avoid the points?  :undecided:
« Last Edit: 06 September 2009, 22:55 by richw911 »
Offline jamie_pyrite
Re: HELP!!!!
« Reply #19 on: 06 September 2009, 11:28 »
Ok so how bad is it?
Any ideas on whatcould be the problem?
Driving home today, the car is perfectly normal up to about 25000 revs, then the turbo kicks in. It seems to lose ALOT of power, the revs reach the limit very quickly but there is still power to a certain extent. If I then change gear it is fine again until the turbo kicks in.
Im hoping its not the turbo on its way out?
First though was a lose pipe, have checked what I can get to and all seem fine. Have left it for an hour, taken it for a drive again and doing the same thing.
PLEASE HELP!! Any ideas greatly welcomed.
Cheers,
Nick
i'm afraid at 25,000 revs.. your clutch isn't going to handle it too well!  :grin:
