Author Topic: AGU Manifold  (Read 2675 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
AGU Manifold
« on: 03 September 2009, 19:45 »
The husband of one of my colleagues has very kindly welded my old manifold up, & I was wondering if any of you guys fancy a crack at swapping it for the duff one currently on my car, please?  (I need saving from the works R reg. Escort van, lol!).  :D
« Last Edit: 17 September 2009, 19:29 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Steve_PD
Re: AG(Poo) Manifold
« Reply #1 on: 03 September 2009, 19:56 »
ok sh!t, R-Techs got a Escort van you could borrow  :grin: :wink: which likes going sideways  :grin:
« Reply #2 on: 03 September 2009, 20:11 »
One's enough thanks! :D
This thing is a proper death-trap!  I think the front & rear halves must be held together with a bit of catering foil & chewing gum, or something!  :undecided:
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 03 September 2009, 20:23 »
give Nick a bell in the morning, should be able to sort something out... can get that TIP swapped over at the same time :grin:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #4 on: 03 September 2009, 21:19 »
hello m8
Not a problem m8, we can get it sorted for you next week if you want?  like Kiss just said, drop us a line tomorrow am to get booked in.
Nik
 01455 617233
« Reply #5 on: 17 September 2009, 14:06 »
I thought you were going to try & sort some ramp time!!!  :P
« Reply #6 on: 17 September 2009, 14:09 »
p.s.  I've now had my OE cat/system put back on the car, because of the split sports cat issue - Will that map you put on the other week be doing any harm to the cat/anything else?  :undecided:
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 17 September 2009, 19:23 »
the cat might get a bit hot, ecu will pull the power if egt's get too high but a spec 1 will probably suit it better
Offline RTechUK
Re: AGU Manifold
« Reply #8 on: 17 September 2009, 22:07 »
Drive it normal you will be ok, ie short blats of power flicking up the gear box. If your pulling from 2500rpm to 6500rpm in very gear and holding full load then your going to get really high egts, the knock control will save the engine from pre det, but not melt down.   The ko3s map runs rich at the top end of the rev range no matter what, this is to help to keep things cooler.
Nick
 01455 617233
Re: AGU Manifold
« Reply #9 on: 17 September 2009, 22:23 »
Cheers, Toph/Nick. :afro:
I only really drive flat out in 2nd/3rd/4th to a max. of 5.5k revs these days, so hopefully I won't melt anything, lol. :)
