Author Topic: ello :-))  (Read 29906 times)
redcarboy
Re: ello :-))
« Reply #10 on: 13 September 2004, 19:50 »
Ain't the prob with the oil light and cut out sommat to do with relay 30?
i changed mine it's? ok now tell me if im wrong peeps. ;D
Thats what got me started on ere now i can't escape. ;D
« Last Edit: 13 September 2004, 19:52 by count-von-carstein »
Offline Overseer
Re: ello :-))
« Reply #11 on: 13 September 2004, 20:39 »
yeah i think it is that one :)
Offline jo
  • im not as think as you confused i am
Re: ello :-))
« Reply #12 on: 14 September 2004, 06:28 »
 :o..have been told bout that one b4...but is it 30...or 36?..number relay?..if they r as cheap as u all bleat on about..?10-?15...then that wot im gonna run out and buy...so...who's in the runnin for the cake then ??..
count..and overseer..hmm..could get nasty..lol ;)
ty guys..will keep ya updated.. :-*
97 mk3 gti
"praise the lowered"
Offline gibby
Re: ello :-))
« Reply #13 on: 14 September 2004, 08:39 »
Jo, wait a minute I want that cake !  ;D So before you run off and buy a new fuel relay check the old one. OK mine's a J reg but I've had this problem on mine and I replaced it last year but the other week it went again, so pull the relay out of the fuse box and check the connections, if you have some build up of black stuff on there then sand paper it off and clean them up, plug it back in and see if that works. If this is the case then you need someone to look at the fuse box as it might need lowering slightly (again if it's like a mk1 and under the passenger kickbar) because cleaning or replacing the relay will only solve the problem until the dirt builds up on the connections again and you will have the same problem. The reason the dirt builds up is because there is a slight gap between the connection in the fuse box to the relay connection. Hope some of this makes sense.  :)
I had to wait 5 - 10 minutes for mine to start after this happened to me and the AA guy said that if you turn the ignition on and you can hear the fuel pump whurr then it should start, if not then don't attempt to start it as you will have to wait another 5 - 15 mins.
By the way, VW were going to charge me ?38 for a fuel relay switch  :(
......now officially dubless.
Offline Len
Re: ello :-))
« Reply #14 on: 14 September 2004, 10:52 »
Relays:- ECU relay is 30. Think Fuel pump relay is 33.
Best thing is to check them first. Warm up engine, (short drive) then take out relays and put then against ur cheek. If warm they are o.k. But check all 4 sides of the relay. If they feel cold to the touch replace. You can do this with all the relays.
ECU relay cost me ?8 and Fuel ?12 (plus VAT)
www.sas.org.uk
www.the-ace.org.uk
Offline gibby
Re: ello :-))
« Reply #15 on: 14 September 2004, 10:56 »
Len, was fuel relay from VW ? Don't know if mk3 is different to mk1 but they lived up to their stealership name as they quoted me ?38 and I was sat at the parts desk at the time, unless they quoted me for some other relay  ???
Offline Len
Re: ello :-))
« Reply #16 on: 14 September 2004, 11:04 »
Yep - my local VAG dealership Mann Egerton. Just off Jcn 16 M4.
Do ya want their number?
www.sas.org.uk
www.the-ace.org.uk
Offline gibby
Re: ello :-))
« Reply #17 on: 14 September 2004, 11:22 »
Don't need number thanks as I've cleaned mine up and it's working, I was just wandering why there was such a difference in price  ???
redcarboy
Re: ello :-))
« Reply #18 on: 14 September 2004, 15:12 »
MMMMMM  TASTY CAKE!  ;D :P
Offline Len
Re: ello :-))
« Reply #19 on: 14 September 2004, 15:17 »
So how come u think ya won the cake eh?
Mind u i am watching my weight so i'll let u have it.  :P ;D
www.sas.org.uk
www.the-ace.org.uk
