Author Topic: Idle issue after TB cleaned  (Read 4366 times)
Offline Rhyso
Re: Idle issue after TB cleaned
« Reply #20 on: 30 August 2009, 20:36 »
and why am i the only one replying.. where's the rest of you lazy lot?? :grin:
dervs don't have throttle bodies  :tongue:
and its about time you did some work around here  :tongue:
Offline golf-sib
  • Турботазик
« Reply #21 on: 30 August 2009, 21:17 »
Going to give the potentiometer ago, anyone got a parts number as I cannot found on on VAGCAT or ebay
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #22 on: 31 August 2009, 00:46 »
iirc you cant get the potentiometer seperate from the tb its part of the assembly probably easier to source a decent used one  :undecided:
2000 Mkiv GTi 1.8T AGU
Offline richw911
« Reply #23 on: 31 August 2009, 21:36 »
Been busy  :grin: :tongue:
Offline golf-sib
  • Турботазик
« Reply #24 on: 31 August 2009, 22:10 »
Some more news, took TB cover off, the potentiometer came a bit unclipped so it didn't move, cleaned the contacts, plugged it up and moved the potentiometer about, the voltages changed, so everything seems good there.
Went to reset the TB with the cover open, I can hear the motor turning but nothing was moving gear wise, now I also got a new error code:
VAG-COM Version: Release  311.2-N
Control Module Part Number: 06A 906 018 CG
  Component and/or Version: 1.8L R4/5VT MOTR HS D02
           Software Coding:
            Work Shop Code:
3 Faults Found:
17967 - Throttle Valve Control part (J338): Fault in basic settings
        P1559 - 35-00 - -
17973 - Throttle Actuator (J338): Lower Stop not Reached
        P1565 - 35-00 - -
01165 - Throttle Body Control Module (J338)
        17-10 - Control Difference - Intermittent
Guessing something is messed up as motor spins but not alignment. Anymore help (like dissembling further?) here or just try and get a new TB?
1.8T AGU..
R135
  24
