Author Topic: Dunlop issue......  (Read 7765 times)
Offline RedRobin
Re: Dunlop issue......
« Reply #10 on: 31 August 2009, 09:33 »
On the subject of tyre pressures I thought that the label on the inside of the fuel filler cap stated 2.5 bar (~36 psi) though I noticed that my VW dealer gave me 39 psi when I recently had new tyres.
So wouldn't 40+ psi result in uneven tread wear?
[Glad you got it sorted, Phil] :afro:
Offline R32UK
« Reply #11 on: 31 August 2009, 16:31 »
Even 2.5 bar seems a little low. I know the R is a little heavier than the GTI but mine states 3.2 Bar all round  :wink:
Offline RedRobin
« Reply #12 on: 31 August 2009, 18:24 »
My GTI came originally on Monza 17's and Continental tyres - Would this make any difference?
:afro:
Offline R32UK
« Reply #13 on: 31 August 2009, 18:45 »
Although I do have mine all at 3.2 bar the figures on my cap suggest slightly differently  :undecided:
Offline Saint Steve
« Reply #14 on: 31 August 2009, 19:22 »
Whats is that in Psi!. Bar is not whats on the forecourt pumps!
Offline R32UK
« Reply #15 on: 31 August 2009, 19:29 »
About 46 psi.
think mine were set to 44psi all round :nerd:
Offline RedRobin
« Reply #16 on: 31 August 2009, 19:43 »
....If you examine most forecourt pumps you'll see that by pressing a button to select bar and then punching in your bar value they will then convert that to psi and display that for the duration as your 'End' limit.
The UK is supposed to be metric!!
Offline Saint Steve
« Reply #17 on: 01 September 2009, 19:25 »
checked mine, and mine says the same 3.2bar
Offline R32UK
« Reply #18 on: 01 September 2009, 19:38 »
Might be 3.2 with 18" and less for the 17". Did yours originally come with 17" RR?
Offline Saint Steve
« Reply #19 on: 01 September 2009, 19:51 »
His did  :smiley:
