Author Topic: VR6_ROB's MK2 VR  (Read 85414 times)
Offline Rhyso
Re: VR6_ROB's MK2 VR
« Reply #20 on: 28 March 2010, 19:43 »
This thread deserves more attention tbh. You should be mighty proud of yourself Rob :afro:
Its because he posts pics of proper stuff instead of talking crap.
Talk crap and you'll get 100 pages plus  :lipsrsealed: :laugh: :laugh:
Top project  :cool: :cool:
« Reply #21 on: 28 March 2010, 19:56 »
+1 excellent work.
Offline cняis
« Reply #22 on: 28 March 2010, 21:04 »
liking this, looks like you're doing a sensible job  :smiley:
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« Reply #23 on: 28 March 2010, 21:50 »
cheers bud thanks for the comments I am over the moon taken me over a year to get to this stage just have not had the time
with the little en and work still a long way to go though and alot more bolts to find I hope to make a show this year
I do look back and was glad to get shot of the citroen ax I had when i joined here :grin:
Offline T_J_G
« Reply #24 on: 29 March 2010, 15:08 »
Love this mate!
The white block makes the bay look even smoother. Top work!
Offline VR6_ROB
« Reply #25 on: 12 April 2010, 23:22 »
fitted my freshly powder coated subframe managed to get the fans mounted to the radiator and got my rear engine mount fitted
i re-routed my power steering so it runs through the pipe in the crossmember and tidied it up
just need to mount the bottle somewhere trying to make something up to fix to the radiator
took the alternator off as it does not move seems jammed also removed the lower inlet some paint in it
and the injectors wont fit so needs sanding down at work tomorrow
sorted the gear linkage got it bolted back on gears are very hard to find though needs setting up
exhaust is on but its not right fix that at a later date
did a little bit more painting on the head
just waiting for the uj joint so i can get the steering back on track
and a couple of engine bits that are getitng painted so i can bolt the inlet back on
Offline VR6_ROB
« Reply #26 on: 18 April 2010, 18:28 »
little update today
got all the hoses plumbed in throttle body needed re-painting to never got managed to fit that
few brackets here and there
rad and fans fitted better
strut brace bolted on
lights fitted although the grill wont sit right on one side
heres one side sat nicely
heres the other side sticking otu slightly
also does this look normal or should it be sat back a bit more at the top
heres the rest of the pics from today enjoy see what you think nearly there now
turned the brake fluid resovoir around so the strut brace does not get in the way
and i need to find a way to mount the header tank might make a bracket to fit from the strut brace
Offline dish
« Reply #27 on: 18 April 2010, 19:31 »
Very nice build thread, love the white on the engine!!!!! Top stuff! :smiley:
Offline dan_apps
  • too low for british roads!
« Reply #28 on: 18 April 2010, 21:04 »
looking good Rob! :smiley:
Offline mattyg127
« Reply #29 on: 23 April 2010, 21:13 »
looks really good  :cool:
Mk4 1.9tdi SE PD100 :D...
