Author Topic: Temp taking a long time to rise to 90° ?  (Read 2489 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Temp taking a long time to rise to 90° ?
« Reply #10 on: 26 August 2009, 22:15 »
If there is a fault here would this be concidered "overcooling"?
Would it coincide with me noticing a slight dip in mpg this week?
more than likely it would  :wink: if its taking about 10 miles to get to 90 i would say that its your thermostat
2000 Mkiv GTi 1.8T AGU
gtigolfthree
« Reply #11 on: 26 August 2009, 22:29 »
Yes all the themostat does is stop the water getting to the radiator until it reaches a certain temperature if it opens too soon or indeed if its open all the time then the warm water will get cooled in the radiator and take for ever to heat up. You will use more fuel while the engine stays cold like being on choke but should be ok once hot.
Offline richw911
Offline Mr_Orange
« Reply #13 on: 27 August 2009, 16:36 »
Journey to work it took 10 mins to warm up, journey home it was fine again!   :angry:
I've ordered the thermostat, o-ring and will get fresh coolant.  I was at a loose end this weekend anyways!
Cracks knuckles.....
Build thread clicky
Offline T_J_G
« Reply #14 on: 27 August 2009, 17:50 »
Did you get a new sensor? If the prob persists you cam try
my sensor :)
Offline Mr_Orange
« Reply #15 on: 29 August 2009, 17:07 »
Thermostat done today with big help from TJG!
Seems fine now, will have to keep an eye on coolant level for next little while is all.
Went out this morning before fitting it and still took ages.  New thermostat and replaced coolant and 90° reached in proper time again.
Easy enough, just a bit fiddly.
Great!
Build thread clicky
Offline T_J_G
« Reply #16 on: 29 August 2009, 17:19 »
All I did was point to stuff :wink:
Offline Mr_Orange
« Reply #17 on: 29 August 2009, 17:48 »
Highlights being some tw@ almost driving over me, or losing that bolt in the deep dark recesses of the engine bay?   :grin:
Build thread clicky
Offline T_J_G
« Reply #18 on: 29 August 2009, 17:52 »
silly Pug driver! your door seemed ok though! I didn't lose it, I misplaced it for a short while.
