Author Topic: Urgent help needed!!  (Read 3672 times)
Offline Adam
Re: Urgent help needed!!
« Reply #20 on: 26 August 2009, 18:22 »
The long lead from the coil pack to the distributor.
Down Hill From Here.
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
« Reply #21 on: 26 August 2009, 18:34 »
so when i try to start it, there should be a spark from distrubutor?
what if there is?
Offline Adam
« Reply #22 on: 26 August 2009, 18:36 »
Take it out of the top of the distributor and do as VW BUSH says,
If there is its not a coil pack.
Offline AudiA8Quattro
« Reply #23 on: 26 August 2009, 18:38 »
Mk3's didn't have separate coil pack, there is a coil and a dizzy.
First unplug no.1 ht lead, check for a spark.
If there isn't then unplug the centre lead in the dizzy, check for a spark.
Offline Adam
« Reply #24 on: 26 August 2009, 18:40 »
Sorry I ment coil.
VW BUSH
« Reply #25 on: 26 August 2009, 18:48 »
Common on Mk3 for Coil to go like this, first thing to check if your car dies
With power and Petrol ok
Offline tobybrennan
« Reply #26 on: 26 August 2009, 19:05 »
well the main lead out of the distributor has a spark and so does no.1 ht lead:)
VW BUSH
« Reply #27 on: 26 August 2009, 19:56 »
You have spark so now, check fuel system :wink:
Offline Mikester
  • Civic Type R
« Reply #28 on: 26 August 2009, 20:23 »
I reckon fuel or ecu relay. Or maybe crank sensor? Failing that maybe the dizzy itself?
« Reply #29 on: 26 August 2009, 21:43 »
It won't be the dizzy as there is a spark.
Check for the fuel pump priming next, or crank it over for about 5-10 seconds, remove a spark plug and smell the cylinder for fuel.
