Author Topic: ABF parts needed? no missing anything?  (Read 4114 times)
VeeDubGTI16v
Re: ABF parts needed? no missing anything?
« Reply #10 on: 23 August 2009, 20:10 »
i thought you needed the crank attached to balance it properly
all my cars have been driven hard lol, the latest one has done about 20,000 road miles and 5 track days with abf fitted.
i just think fitting a cable change without doing a lot of work to it is a step backwards. ill just replace the box if it goes until a proper cable change box is built
ive temped fate now havent i. expect a 'i have blown up my gearbox' post on wed eve
Offline danny_p
« Reply #11 on: 24 August 2009, 01:38 »
in olden days it used to get balanced as an assembly but there all indevidualy done now,   when you think about it ALL the 2ltr petrols have the same cranckshaft so even have varying types of flywheel bolted to them.
main reason machene shop wants the cranck is so they can just pllonk the lot int he balancer if you give them just a flywheel thay have to have or make a boss to hold it.
ooops
« Last Edit: 24 August 2009, 14:44 by danny_p »
all the VW's have gone bar 1.
Offline Diamond Hell
  • Opinions я Us
« Reply #12 on: 24 August 2009, 13:11 »
had my flywheel balanced via merlin motorsport at coomb,  tho piston broke  did the machening
No you didn't, it was machined by Piston Broke and then balanced by an unknown party through InterPro at Thornbury.  :tongue:
Mine was lightened and balanced by http://www.jnlracing.co.uk/ when I had my head breathed on.
There are two choices when balancing, really.
Either you can balance the flywheel on it's own, or you need to balance the flywheel and the complete rotating mass of crank, rods and pistons, oh and the clutch ,too.
I think it's safe to assume that VW build the engines as a 'built' unit, so the balancing tolerances are resonably close.  As Danny's said they fit a number of different types of flywheels to the motors, so these are probably made and balanced separately.  Likewise, the clutches would be manufactured and balanced at another factory, completely separately.  The benefit of the lightened flywheel is most easily accessed by just getting the unit lightened and balanced.  My and Danny's flywheels haven't torn the motors to pieces yet, although as eny fule no, I do drive like a girl and am frankly, rev-o-phobic.
Depending on the application, the cable-changer does have another great benefit, in that it allows you to re-position the shifter mech nice and high up, which makes quite a big difference to how fast you shift.  We did Danny's some time ago and I will definitely do mine when I do another batch of work on my car, only I'll go even higher than his, so the shifter falls to hand even better.
If the motor and box are out I would say 'fit a cable-changer' - it's going to be a pain to have everything out again if you blow up the box shortly after.  Plus the CDA box, although quite leggy is a well-matched set of ratios to the application.  The Toledo I killed recently worked very well with this set of cogs and unless you're taking the car on track regularly and *want* sprint gearing I'd say stick with stock on that front.
Offline danny_p
« Reply #13 on: 24 August 2009, 14:47 »
well it was half right ish.    it went away it came back later
