Author Topic: Golf Mk4 20v cam belt changing, DIY????????  (Read 6063 times)
Offline ianholt1
« on: 22 August 2009, 20:21 »
Hi all,
I have been reading some of the advice on this forum and there seems to be some very knowledgable members,
I have had my 1999 Golf for about 4 years now and it has been a fantastic car, if a little slow! It has done 108K and is in need of a new cambelt asap. Is this a job for a garage or could a competent mechanic handle this job? It is a 1.8 20valve (non turbo).
Thanks Ian
Offline danny_p
Re: Golf Mk4 20v cam belt changing, DIY????????
« Reply #1 on: 22 August 2009, 20:33 »
not that hard as long as you have an idea about what your doing
all the VW's have gone bar 1.
Offline AliBailey88
« Reply #2 on: 22 August 2009, 21:05 »
easy enough if ur mechanically minded, did myne in 2hrs with water pump and coolant change.
If u time it up wrong expect a fooked engine.
Offline ianholt1
« Reply #3 on: 23 August 2009, 08:53 »
Thanks for the replies, Are there any specialist tools needed?
Ian
Offline AliBailey88
« Reply #4 on: 23 August 2009, 20:16 »
no, just line up the crank sprocket and the cam with its marks. Turn over a few times once belt is on to make sure both marks are aligned and belt tension is ok.
Offline ianholt1
« Reply #5 on: 27 August 2009, 21:54 »
Does any body know if the water pump is external on the 1.8 20valve non turbo. Or will I need to remove the cam belt again to change it?
Offline AliBailey88
« Reply #6 on: 28 August 2009, 06:31 »
u need to remove the cambelt, held in by 2x 10mms and a big rubber washer.
Offline ianholt1
« Reply #7 on: 01 September 2009, 11:10 »
Have been looking for a belt kit and was supprised to find VW very good. A local garage want £85 for a non gen belt kit and £230 fitted but Heron VW at Newark want the same for genuine parts. Gonna give it a go myself tomorrow, wish me luck?
Offline ianholt1
« Reply #8 on: 10 September 2009, 19:51 »
Cam belt and water pump all done now. Thanks for the advice. Just out of interest how the f*ck do you remove the engine mount, the manual said to manipulate it from beneath but no matter how i tried it would not come out. I tried lifting and lowering the engine and levering it about but ended up working around it!
Next job = Clutch. any advice?
Offline AliBailey88
« Reply #9 on: 12 September 2009, 21:26 »
ah yea, i remember the engine mount get me hot and frustrated but got it out it the end.
