Author Topic: Erratic Idle  (Read 27592 times)
Offline DanoGTI
Re: Erratic Idle
« Reply #30 on: 25 August 2009, 08:52 »
 :grin:
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
Offline Teutonic_Tamer
Re: Erratic Idle
« Reply #31 on: 25 August 2009, 11:50 »
Just had a quick scout around but couldn't find anything worth posting, but basically would it be fair to say that if the PCV valve is obviously under positive pressure (boost?) then remapping will increase this pressure and lead to premature failure of the diaphagm?
Would that make sense TT?
Sam
The PCV valve has NOTHING to do with turbo boost!  :rolleyes:  It is ONLY the DV which is affected by turbo boost, unless you have modified your engine to work on the two stroke cycle!
The PCV valve may have nothing to do with boost,  but it can be affected by it.  Therefore increased boost can damage it.
Crankcase Ventilation
The crankcase is maintained in a constant
vacuum while the engine is running.
The crankcase breather that supplies
this vacuum is connected to the intake
manifold.
The crankcase blow-by gases are separated
in two stages. In the first stage, the
primary oil separator in the oil filter module
takes most of the oil out of the gases. A
second separator in the cylinder head cover
removes the remainder of the oil from the
gases.
Since a turbo engine requires a more
sophisticated pressure control system, a
two-stage pressure control valve is located
on the cylinder head cover. If vacuum exists
in the intake manifold, blow-by gases flow
directly into the intake manifold.
If a boost pressure is present in the intake
manifold, a one-way valve in the pressure
control valve housing closes and the blowby
gases flow into the cylinder head cover
ahead of the turbocharger.
The system can
detect faulty installation of the pressure
control valve. Unmetered air is detected by
the reaction of the oxygen sensor.
Where - exactly did that blatant cut, copy and paste come from?  Because that categorically is NOT from a Volkswagen Group FSI engine?  And there are some serious, and fundamental basic errors with that!
And I will categorically state again, boost pressure has absolutely NOTHING to do with the PCV - nothing!  Furthermore, it can NOT be affected by boost either.
But hey, you read and stole the above from some other internet forum, so that then means it must be true!  :rolleyes:
Didnt say it wasnt a copy and paste.
It was copied and pasted from the 'self study guide' for the GTI engine
Have you read it :rolleyes: :rolleyes:
Plus YOU got that guide from from the SAME internet forum as I did so it must be true.
Page 8 I think you will find.
Still stand by your
http://www.golfmkv.com/forums/golfgoodies/mk5golfengine.pdf - Self-Study Programme
Yup, I still stand by my claim.  Sadly, you seem to be utterly gullible if you honestly think crankcases work on a 'vacuum'.  Go and read Hillers.  That PDF is simply a 'dummed down' guide for the Yankie audience (whos' intelligence is debatably considerably less than ours).
Here is another mistake from the same said PDF:
Quote
High-pressure oil pump drive from a
triple cam on the intake camshaft
I suppose you believe that as 'gospel truth' too!  :rolleyes:
I feel like a homo
Re: Erratic Idle
« Reply #32 on: 25 August 2009, 11:51 »
:grin:
What's so funny?  Look at my subsequent reply.
I feel like a homo
Offline DanoGTI
Re: Erratic Idle
« Reply #33 on: 25 August 2009, 12:38 »
Lol- I'm not the one coming across as a total cock :smiley:
listen T-T, there's no doubting your valuable input into this site but lighten up. Just because there are a great many users who don't have your wealth of knowledge nor experience doesn't excuse the level of arrogance you seem to demonstrating.
« Last Edit: 25 August 2009, 12:39 by DanoGTI »
DA Productions
Offline sambo
Re: Erratic Idle
« Reply #34 on: 25 August 2009, 14:51 »
Just out of interest T_T and I hope you don't mind me asking but, I notice you are retired now? Did you retire early or are you at that age where it come's naturally?
I won't ask how old you are as it's rude!  :shocked:
Sam
« Last Edit: 25 August 2009, 15:03 by sambo »
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline VWjon
Re: Erratic Idle
« Reply #35 on: 25 August 2009, 16:47 »
Only came here to post the fact every time I see the thread title this is what I think.........
Always look on the bright side of life............... do do...........
MKV Black GTi ¦ 3 Door ¦ Manual ¦ Leather ¦ Monza II ¦ Armrest ¦ iPod ¦
Mods:- Smoked Wing Mirror Indicators
Future Mods:- RNS510 Stereo
Offline DanoGTI
Re: Erratic Idle
« Reply #36 on: 25 August 2009, 16:53 »
 :grin: :grin: :grin: :grin: :grin:
DA Productions
Offline AlanD
  • MK5 2.0T 16v
Re: Erratic Idle
« Reply #37 on: 25 August 2009, 16:56 »
Well, Im glad this thread was of service. Shes getting VAGed (yes I have just invented a new word) tomorrow so will update tomorrow or Thursday depending on what time I get back from Brands.
Offline Ben
Re: Erratic Idle
« Reply #38 on: 25 August 2009, 17:25 »
Its the remap go and get your money back!!!! :angry:
Opps!  Be reading too much on certian Seat owners forum...lol
Nick
the dwarf from the north
Offline ukdub
  • WH05 DUB its my DUB
Re: Erratic Idle
« Reply #39 on: 25 August 2009, 17:47 »
T-T you told people to go read that Self study to see how the PCV system works.  Then you basically say that what VW have written is wrong and your right. Make your mind up.
You will be telling us next that you know more about the Space Shuttle than NASA does.
Laser blue with BBS CH wheels in 19"
APR software, APR RSC turbo back exhaust, APR HPFP, Dbilas flowmaster intake, KW V3's
BSH speedshop PCV stage 2 fix but with Forge catch can
