Author Topic: What Engine do i have?  (Read 2293 times)
Offline christomk3gti
Re: What Engine do i have?
« Reply #10 on: 20 August 2009, 11:22 »
Are the AGG Engines better?
Black 8v GTI............. Whats a Waffle Valve?
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 20 August 2009, 14:58 »
Possibly the worst all rounder!  :lipsrsealed:
It was the 1995 emmision regualtions engine (less emmisions less performance..2e's are best and more tunable due to the bosch injection)
« Reply #12 on: 21 August 2009, 10:04 »
How much in difference then? and can i change the injection unit then?
« Reply #13 on: 21 August 2009, 10:07 »
Not that easy to be honest.
Offline shepgti
« Reply #14 on: 21 August 2009, 10:16 »
wooo cmon the 2e's!
« Reply #15 on: 21 August 2009, 10:29 »
how much in difference is it from the 2e.? in power....torque..
Offline shepgti
« Reply #16 on: 21 August 2009, 16:35 »
http://boneybradley.webs.com/theengines.htm
  • Back in a Mk3...
« Reply #17 on: 21 August 2009, 19:33 »
injection on the ady and agg is the same but the 2e uses bosch injection which seems to be much more reliable and easier to set up then the simos system
« Reply #18 on: 22 August 2009, 00:03 »
Cheers for that.
just wanted to know that there both the same power really...
but good to know. Cheers
Offline bored_Welsh_lad
« Reply #19 on: 24 August 2009, 03:38 »
whip off the distributor cap, if its a single window its an agg if its a 4 window its a 2e
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
