Author Topic: What upgraded brakes for 1987 Mk2 Gti 16v ?  (Read 9212 times)
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: What upgraded brakes for 1987 Mk2 Gti 16v ?
« Reply #10 on: 14 August 2009, 12:56 »
Imo definately buy a NEW master cylinder, its not worth messing around with a second hand one, trust me we went through 7 litres of brake fuild trying to get mine done because the freaking seals kept going on a second hand ones. Only like £50 on the bay :)
Offline s1monc
« Reply #11 on: 14 August 2009, 13:05 »
Thanks for the replys :smiley:, what brake pads do most people use for trackdays, i used to use Performance Friction carbon metalic pads on the M3 & they were awesome with no fade, also a few guys i know use Carbotech pads but i'm not sure what is available for the Golf, i would rather spend good money on some proper pads that won't fade, i have never heard any good reports about EBC  but i suppose the Golf is a very light car compared with what i'm used to so may work on a Golf.
Cheers Simon.
Offline Horney
« Reply #12 on: 14 August 2009, 13:06 »
I run Mintex Extreme pads on my Track MKII and they're awesome but I believe these are no longer available which is a bummer as mine need replacing! I was thinging of going EBC black Stuff.
Nick
Offline s1monc
« Reply #13 on: 14 August 2009, 13:06 »
Yes deffo a new master cylinder not a second hand one !
Offline danny_p
« Reply #14 on: 14 August 2009, 13:16 »
EBC YELLOWS   work well on golf
all the VW's have gone bar 1.
Offline Diamond Hell
  • Opinions я Us
« Reply #15 on: 14 August 2009, 13:37 »
280mm front brakes can be sourced from Seat Cordoba 16V for definite, probably Ibiza 16V, but not the Toledo 16V (it's 5-stud).  You *may* find 280mm fronts on 16V Passats, too.  lowlier Passats certainly have 256mm set ups, which do just bolt up, same as the 280mm, except for rotors, pads and caliper carriers.
If you're stripping the Golf, in all seriousness, with 280mm front brakes, on Zimmerman rotors and good OEM spec pads you won't go far wrong and I'd be VERY surprised if you cooked the pads - 280mm rotors are big ole bells.  Even with R888s on I've not managed to get any fade from my brakes, although I do drive slowly and like a girl, according to some people.  My experience would be from driving 'ring, Combe, Goodwood and sometimes even on public roads.
Offline Horney
« Reply #16 on: 14 August 2009, 13:49 »
Lovin your new sig DH.
Nick
Offline s1monc
« Reply #17 on: 14 August 2009, 13:57 »
Can i just say as a new member on here i am very impressed with the amount of replies & really useful information helping me to understand which is the best way foward on the brakes, very friendly site :smiley: Looks like i'll have no probs when i start asking about suspension etc !
Thanks Simon.
Offline Horney
« Reply #18 on: 14 August 2009, 14:02 »
Thanks Simon.
Koni top adjustables and -40mm Eibach springs, poly bush everything, G60 top mounts and top strut brace. :grin:
nick
Offline danny_p
« Reply #19 on: 14 August 2009, 14:43 »
Thanks Simon.
nick
thats the optimal setup
