Author Topic: 0-60 time  (Read 14751 times)
Offline keelaw
  • It's here!
Re: 0-60 time
« Reply #20 on: 16 August 2009, 21:58 »
i hear what you're saying R32UK, however at the end of the day if different cars have different gearing, then thats a true life reflection of their performance.  no measure will be absolutely perfect.
Erm, you are aware that cars can drop gears?
You couldnt do that test in a DSG for example as it will drop to the optimum gear; what you are supposed to do!
not quite sure what you mean.  if i was doing a 30-70 through the gears test then I'd just try several times, trying to start in 2nd or maybe even 1st and then working up the gears.
i don't think the 30-70 test means starting in a higher (cruising) gear and then dropping down some gears to the optimum and then work up to 70.  i think that's why they have the 30-70 in 4th gear (or top gear) test... tho that is just cruising flexibility... and autos cane that test since they kick down whereas manuals will be forced to stay in gear.
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
