Author Topic: Front wings  (Read 1965 times)
Offline stu 88
  • Looking for a cheap set of 17's
Front wings
« on: 12 August 2009, 09:06 »
Just a quick one - Is it worth getting pattern front wings or should I go for gen VW?  Ive just picked up another Mk3 that needs 2 front wings, Is there a diffrence between std golf and gti wings- they are all bolt on arnt they??
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Front wings
« Reply #1 on: 12 August 2009, 09:08 »
For obvious reason genuine will always be a better fit and made from better material but then it boils down on how much money you have to spend really. As far as i'm aware all the wings are the same regardless of been a GTI or not and simply boly on/off.
Have you thought about getting a couple from a breakers yard?
Offline stu 88
Re: Front wings
« Reply #2 on: 12 August 2009, 09:27 »
No didnt think about going to the breakers - Ill do that this weekend
gtigolfthree
Re: Front wings
« Reply #3 on: 12 August 2009, 09:36 »
The vw ones will probably last another 15 years, but will the car?
Offline Mikester
  • Civic Type R
Re: Front wings
« Reply #4 on: 12 August 2009, 09:52 »
I paid a tenner for one at a breakers. Remember the indicators changed in 95 to oval from square.
Offline VR6-Joe
Re: Front wings
« Reply #5 on: 12 August 2009, 11:09 »
Also worth noting that GTI's came with the plastic arches too. I bought a GTI wing for my non GTI and when I removed the plastic arch I found the wing to be rotten. Took it back and swapped it for a non GTI wing :)
Oh and another thing, I think the later SE's/GTI's/VR6's came without an aerial hole :wink:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline ace
Re: Front wings
« Reply #6 on: 12 August 2009, 11:21 »
i would personally go for genuine vw wings, i know of people that have bought non-genuine parts an within 6mths - 1year had problems with them. also u may not get an exact fit from them and panels not lining up properly
Re: Front wings
« Reply #7 on: 12 August 2009, 15:50 »
Yup, 96 onwards had roof mounted aerials
Offline VR6_Wherry
Re: Front wings
« Reply #8 on: 12 August 2009, 16:15 »
Really...my 93 has a roof mounted ariel??  :undecided:
Re: Front wings
« Reply #9 on: 12 August 2009, 16:45 »
Oh ok i thought they were fitted to the later mk3's as mentioned above on the change over year, 96. Quite a few little tweaks and updates were applied then as far as i'm aware....unless yours was fitted as an aftermarket item?
