Golf mk3
hardmonkeys
disks under thickness
Topic: disks under thickness (Read 1719 times)
karlos28
Re: disks under thickness
Reply #10 on:
12 August 2009, 12:41 »
small detour if thats alright.. mine has a similar thing.. but the discs are solid.. i dont have any choice but solid discs again do i.. unless i replace the calipers coz the vented ones are wider, correct?
axewielder
95 dragon 8v
Reply #11 on:
12 August 2009, 13:38 »
yep solids are like 10-12mm and vented are 22 so most likely new calipers but not sure they would bolt straight up, might need a spacer? have to ask someone whos done it.
karlos28
Reply #12 on:
12 August 2009, 18:18 »
think il stick to solids.. makes life much easier! maybe get some drilled ones..?
axewielder
95 dragon 8v
Reply #13 on:
12 August 2009, 18:54 »
id go for grooved if anything, the holes encourage cracks to form lol
gtigolfthree
Guest
Reply #14 on:
12 August 2009, 19:04 »
Pinched this from the mk4 section its a good read anyway.
http://uk-mkivs.net/forums/t/153276.aspx
VW BUSH
Guest
Reply #15 on:
12 August 2009, 19:30 »
If you are in an accident and your car gets checked over and the discs are under size it will void the MOT and insurance etc and you could be looking at bird
axewielder
95 dragon 8v
Reply #16 on:
12 August 2009, 19:49 »
yeh ok enough with the safety advice ive said ill change them
Golf mk3
hardmonkeys
